phone  (937) 890-5197
Shopsmith Forums
%nbsp;
26 posts 1 2 3
Re: Smithy Super Shop FM 73500
#261958 by rpd » Thu Aug 15, 2019 12:34 am
And the coupling video.
#262047 by KilnBilly777 » Sat Aug 17, 2019 2:08 pm
More you tubes under Smithy to figure out powering my SS band saw
#262052 by rpd » Sat Aug 17, 2019 3:38 pm
KilnBilly777 wrote:More you tubes under Smithy to figure out powering my SS band saw
#262058 by rpd » Sat Aug 17, 2019 5:02 pm
These videos should help on how the Bandsaw blade tracks on the wheel.
#262078 by rpd » Sat Aug 17, 2019 10:14 pm
Page 18 of the manual says that all accessories are powered from the lower left shaft, not the draw bar, but doesn't say how to address the height dependency. :confused:
Re the coupler, note that hub that goes on the headstock will have four (4) grooves, this will mate with the end of the coupler that has the spring. the two loose hubs in the video go on the accessory (bandsaw) and have five (5) grooves.
Does the hub that is mounted on the lower left coupler have a 5/8" hole and a setscrew?
You could try mounting the bandsaw on the right end where the tailstock normally goes, and put the drive hub on the spindle in place of the saw arbor. Reverse the motor rotation so the blade turns in the correct direction.
#262589 by KilnBilly777 » Mon Sep 09, 2019 6:02 pm
Two things Learned. Remove The Draw Bar And The Couple To The Bandsaw attaches Perfectly.
Next, The Blade On The Band saw Need Not Be Centered. It Rides Better To The Back. Meant That Way.
Steve
Who is online
Users browsing this forum: No registered users and 87 guests
Subscribe to our mailing list
* indicates required
