phone  (937) 890-5197
Shopsmith Forums
%nbsp;
4 posts • Page 1 of 1
radius sanding
#234427 by marcs4095 » Fri May 19, 2017 3:04 pm
In building a banjo I needed two 3x5" maple blocks sanded to an 11" radius.To do so, I first mounted a strap hinge 3/4" above the table to my rip fence with T-blocks and 1/4-20 bolts. With J&B Weld epoxy, I mounted a 1/4" shelf hanger bracket to the end of the hinge.
I next made a supporting frame with 1/4 hole for the bracket to engage. This frame supports the block upright to be sanded such that the center of the pivot is 5 1/2" (half the 11" diameter) from the face of the block. The block is then attached with 2-sided tape and the fence is adjusted such that the block is well supported by the edge of the table. (I don't trust the 2-sided tape that much!)
I just barely touch the face of the block to the sanding disk as to take off small increments at a time. I feed the block into the sanding disk against the motion of the disk; remove the block support and block from the hinge pin; bring it to the back; reassemble and repeat.See photo.
Re: radius sanding
#234428 by marcs4095 » Fri May 19, 2017 3:07 pm
This jig is also handy for sanding various sized disks such as a table top. I have shown it here to illustrate the point. Of course, for larger table tops you will need to make a spacer between the hinge and the rip fence and likely need to use an auxiliary table for the rip fence. See attached photo.
Re: radius sanding
#234437 by rjent » Fri May 19, 2017 9:06 pm
Don't see a picture.... :/ Would love to see how this works! :cool:
Dick
http://www.shopsmith.com/ss_forum/maintenance-and-repair-f10/reborn-10er-t15205.html#p175987
1950 10 ER S/N ER 39671
1951 jigsaw
1951 !0 ER #3 in rebuild
500, Jointer, Bsaw, Bsander
Planer
Re: radius sanding
#234442 by skou » Sat May 20, 2017 12:37 am
rjent wrote:Don't see a picture.... :/ Would love to see how this works! :cool:
Yeah. Two of us! :D
steve
10 ER, stripped down.
Who is online
Users browsing this forum: No registered users and 13 guests
Welcome to Shopsmith. Please fill in this form and we'll send you more information about the Shopsmith MARK 7 and other woodworking topics.
First Name: Last Name:
Address:
Optional Extra Address Line:
City: ST: Zip:
Email:
Re-Enter Email Address:
Phone: ( ) -
NO - I do not yet own a MARK 7 or Mark V
YES - I own a MARK 7 or Mark V
Submit
