phone  (937) 890-5197
Shopsmith Forums
%nbsp;
174 posts • Jump to page: 1 13 14 15 16 17 18
Re: Gallery of Restorations
#201609 by JPG » Tue Jan 12, 2016 9:13 pm
My intent is to make an adapter ala Shipwright's inherited one.
I may add tube extensions anyway. ;)
Goldie(Bought New SN 377425)/4" jointer/6" beltsander/12" planer/stripsander/bandsaw/powerstation /Scroll saw/Jig saw /Craftsman 10" ras/Craftsman 6" thicknessplaner/ Dayton10"tablesaw(restoredfromneighborstrashpile)/ Mark VII restoration in 'progress'/ 10E(SN E3779) restoration in progress, a 510 on the back burner and a growing pile of items to be eventually returned to useful life. - aka Red Grange
#201616 by jsburger » Tue Jan 12, 2016 9:53 pm
JPG wrote:My intent is to make an adapter ala Shipwright's inherited one.
Link?
#201619 by BuckeyeDennis » Tue Jan 12, 2016 10:27 pm
Link?
maintenance-and-repair-f10/mystery-parts-t4889.html
#201685 by jsburger » Wed Jan 13, 2016 7:39 pm
Link?
Thanks, I remember that one now.
#201709 by skou » Wed Jan 13, 2016 9:36 pm
Guys, I was able to adapt a Mk series "Ponytail" headrest to one of my Model 10s.
It worked just fine, and was strong enough to lift the right end of the bench
off the ground, when I pulled on the bandsaw I had.
Yes, it looked "FrankenSmith" but worked in all respects, except I could no
longer mount a Model 10 extension table on the left end. (A Mark series ext
table WILL fit, though.)
steve
10 ER, stripped down.
#203615 by hobbies » Thu Feb 04, 2016 8:26 pm
is there a limit to how much sanding you can do on the way bars?
#203616 by ERLover » Thu Feb 04, 2016 8:45 pm
I would think so by the limit of how tight the things on the way tubes will tighten, but I have no experience on that limit, I am sure some here might. I know that did not help much.
#203617 by rjent » Thu Feb 04, 2016 9:11 pm
hobbies wrote:is there a limit to how much sanding you can do on the way bars?
How much do you require? I see no practical limit because of the method of the clamps used on the ways.
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw
1951 !0 ER #3 in rebuild
#203624 by JPG » Thu Feb 04, 2016 11:40 pm
A more relevant question is, when is it enough?
IMHO when the surface rust is gone. The pits are a visual defect, not a functional one. Too many pits concentrated in one area likely makes it unusable however placing them facing down will make them usable.
#203627 by skou » Fri Feb 05, 2016 12:10 am
Guys, the registration requires close tolerances on the way tubes.
Go easy on sanding them down too much. Get the surface rust
off, and don't worry about the "pits." Pits will hold oil to
lubricate movement.
OK, at a time in my past, I worked on a printing press.
Registration, is the numerous press heads hitting the
same point. (The red,yellow, black and blue inks line
up.)
Registration on a SS, is not that critical, but it is
important. If your way tubes are too small, you'll
have issues. Go gently there.
Also, Mark series way tubes are MUCH thinner, than
my Model 10 tubes. (I've got almost 1/4 inch tube
thickness to play with.)
Yes, Model 10 tubes WILL fit on a Mark series machine.
steve
Who is online
Users browsing this forum: cmc and 105 guests
Subscribe to our mailing list
* indicates required
