phone  (937) 890-5197
Shopsmith Forums
%nbsp;
4 posts • Page 1 of 1
New to Forum
#19921 by webzter » Sun Jul 27, 2008 10:34 am
I just purchased a used 1992 Mark V model 500. The original owner only used the drill press and was stored in an unheated garage. I was told it was seized so I got it for a really good price. I found that the Quill Feed Sleeve has rusted and was seized in the head stock housing. I have tried a penetrating liquid but it still won't budge. Does anyone have any suggestions on how to free up this sleeve with out damaging the housing?
#19923 by a1gutterman » Sun Jul 27, 2008 11:17 am
Imagewebzter,
Although I do knot usually recommend whacking the Mark V with a hammer, but if it truly is only rust preventing the quill from moving, one thing that you could try is this: Put something, like an empty saw blade arbor, on the shaft, to protect the end of the shaft, and give the end of the shaft a good whack. This might break loose the rust. This method has helped me with similar (non-ShopSmith) situations. Hopefully someone else has a better idea! Good luck.
Tim
Quill Feed Sleeve
#19925 by billmayo » Sun Jul 27, 2008 12:27 pm
To make sure we are talking about the same thing, you cannot turn the quill feed assembly shaft. If the quill housing is stuck in the headstock, you will have the same symptom. The quill feed sleeve is held on the quill feed pinion by a woodruff key. This holds the sperical washer on the shaft and prevent the shaft from beening removed. You have to remove the woodruff key sometimes before you can remove the sperical washer. In either case, I remove the motor, speed control assembly and idler shaft assembly and turn the housing upside down so I can see the inside of the housing. There are 2 big ears holding the quill housing so limit any prying on the ears if possible. I try to use the quill housing or the quill feed shaft as a pivot point when trying to move the sperical washer and quill feed sleeve. I use heat (heat gun) only on the aluminum area and Kroil (good penetrating oil) on the rusty part in the stuck area and try to move the stuck part with a pry bar or big screwdriver. A hammer around the headstock can be dangerious for the aluminum headstock. It does break. Always protect the end of any shaft before tapping on it. I sometimes soak the area with Kroil and let set overnight before try to move anything.
webzter wrote:I just purchased a used 1992 Mark V model 500. The original owner only used the drill press and was stored in an unheated garage. I was told it was seized so I got it for a really good price. I found that the Quill Feed Sleeve has rusted and was seized in the head stock housing. I have tried a penetrating liquid but it still won't budge. Does anyone have any suggestions on how to free up this sleeve with out damaging the housing?
Bill Mayo [url]bill.mayo@verizon.net[/url]
#19932 by webzter » Sun Jul 27, 2008 3:41 pm
billmayo wrote:To make sure we are talking about the same thing, you cannot turn the quill feed assembly shaft. If the quill housing is stuck in the headstock, you will have the same symptom. The quill feed sleeve is held on the quill feed pinion by a woodruff key. This holds the sperical washer on the shaft and prevent the shaft from beening removed. You have to remove the woodruff key sometimes before you can remove the sperical washer. In either case, I remove the motor, speed control assembly and idler shaft assembly and turn the housing upside down so I can see the inside of the housing. There are 2 big ears holding the quill housing so limit any prying on the ears if possible. I try to use the quill housing or the quill feed shaft as a pivot point when trying to move the sperical washer and quill feed sleeve. I use heat (heat gun) only on the aluminum area and Kroil (good penetrating oil) on the rusty part in the stuck area and try to move the stuck part with a pry bar or big screwdriver. A hammer around the headstock can be dangerious for the aluminum headstock. It does break. Always protect the end of any shaft before tapping on it. I sometimes soak the area with Kroil and let set overnight before try to move anything.
Thanks for your help. I managed to break the sleeve into small pieces and remove all of the parts. No damage to the housing thankfully.Now all I have to do is order a new sleeve and I should be able to start using my new toy. MJ
Who is online
Users browsing this forum: No registered users and 126 guests
Subscribe to our mailing list
* indicates required
