Smithy Super Shop FM 73500
Re: Smithy Super Shop FM 73500
KilnBilly777 wrote:Blade Self Centering is standard. I've been told now that 95% of problems are eliminated by a "new" blade. My next problem is the link (coupling Kit) from the power head to the band saw does not work from everything we've tried. It should connect from the collet draw rod port (Upper Port) to the band saw shaft. But, the connection collars - end is wrong and does not match the upper port. We ruled out using the power take off (lower Port) as it is too low to match up. Without manuals it's tough. We may be missing a part. Steve
And the SS bandsaw is NOT standard(the reason to know if it is a SS clone).
I think we need pix of what you have. Few of us have seen a machine like yours.
beeg
Post by beeg »
beeg wrote:Do you have both drive hubs?
https://www.shopsmith.com/ownersite/cat ... oupler.htm
What he does NOT have is the SS shaft for the driving hub.
KilnBilly777
Post by KilnBilly777 »
The YouTube description of the coupling problem cans be seen on KilnBilly777 under Smithy Bandsaw Coupling
Steve
KilnBilly777
Another YouTube picture of my problem.
Look up KilnBilly777 and see the Smithy Super Shop Coupling Attachments. Great but no instructions. Steve
KilnBilly777
Take a look on YouTube under KilnBilly777 for Smithy Super Shop Band Saw & Couplings for the Super Shop Nd FM7300 11” Band Saw. Steve
rpd
Post by rpd »
Found the link to the video. The bandsaw appears to be a clone of the SS bandsaw, No idea about the coupler.
[youtube]https://www.youtube.com/waSmithy Bandsaw Couplingtch?v=Ddl2sIHzsGY[/youtube]
KilnBilly777
The you tube ended up under Smithy Super Shop Couplings Ans Smithy Bandsaw Coupling. Never showed up under KilnBilly777. Amateur I’m Sure
KilnBilly777
Thanks. I’m looking.
KilnBilly777
Where you found the link is also a you tube of the Coupling kit
