Using a Shop Smith Mark V on a Chris Craft Roamer refit
roamer46
Re: Using a Shop Smith Mark V on a Chris Craft Roamer refit
Post by roamer46 »
We got two more Whisper Wall Headliner panels and Kai LED lights installed in the salon. This it turning out really nicely.
Next up in our 1969 Chris Craft Roamer 46 Refit: Salon Headliner Install II
Cheers,
Q
roamer46
Post by roamer46 »
Drumroll please...the Whisper Wall headliner in the salon and galley is done. And it looks great!
1969 Chris Craft Roamer 46 Refit: Wrapping Up the Salon Headliner Install
Cheers,
Q
roamer46
Post by roamer46 »
While the headliner installer has been working his magic, I've been tinkering around with other stuff that keeps me out of his way. This time around, it's V-berth moldings to cover up all of those exposed mahogany edges. The mahogany I used was from the old wing doors I broke down and jointed back in February. It's gonna look great when it's refinished with ICA clear coat...a lot better than it looked covered with white paint for 50 years!
1969 Chris Craft Roamer 46 Refit: V-birth Moldings
Cheers,
Q
roamer46
Post by roamer46 »
Before I put ICA 2-part urethane clear coat on the moldings, I wanted to have a bigger pile of mahogany needing varnish. That ICA stinks, so if I'm going to mix it up and break open carbon filters I want to make sure I get a lot of wood coated. So I jumped back into the aft stateroom and fitted a couple of mahogany panels at the transom. In doing so, the mahogany stack dropped by 1/2". When the plywood stack is gone, the project should be finished.
"Progress"
1969 Chris Craft Roamer 46 Refit: Aft Stateroom Transom Panel
Cheers,
Q
nuhobby
Post by nuhobby »
Looking Great! Your patience and persistence is an inspiration.
Reminds me of an old song....
Mahogany....
Do you know, where you're going to ? :)
Chris
roamer46
Post by roamer46 »
Thanks Chris!
Speaking of mahogany, I've got 15 4x8 sheets coming tomorrow!
Cheers,
Q
roamer46
Post by roamer46 »
While the headliner was being installed, I was working on other stuff. With the V-berth moldings and aft stateroom transom mahogany plywood cut and fitted, next I mixed up the stinky ICA urethane basecoat and brushed it on. It's always nice to see the wood grain POP when you hit it with varnish.
1969 Chris Craft Roamer 46 Refit: ICA Basecoat on Moldings and the Aft Stateroom Transom Panel
Cheers,
Q
roamer46
Post by roamer46 »
I got that back panel installed in the aft stateroom. That did a lot to hide a big patch of spray foam insulation I was sick of looking at. Now it's pretty mahogany.
1969 Chris Craft Roamer 46 Refit: Installing the Aft Stateroom Transom Panel
Cheers,
Q
roamer46
Post by roamer46 »
On Tuesday, I posted a new blog article...and then my computer keyboard bit the dust. I haven't even been able to login until today when I finally got a replacement keyboard that works. Anyway, the article from Tuesday is pretty cool. In preparation for some epic mahogany work I need to do on the aft deck as part of the prep for the headliner install back there, I took some 8/4 (2" heavy) x 14' long boards to a local shop and had them resawn down to 1" thick. Then I cut those to useful sizes and ran them over my jointer. If you're into wood porn, this article's for you.
1969 Chris Craft Roamer 46 Refit: Resawing Big Mahogany Boards
Cheers,
Q
Before
After
roamer46
Post by roamer46 »
I've been jumping around from topic to topic recently, all over the boat, because lots of stuff has been going on while the headliners were being installed in the V-berth, salon, and aft stateroom. One of the things I contracted out was to have the headliner installer put padded Whisper Wall on the walls surrounding where the mattress will go in the V-berth. I'm really happy with the work this installer has done. It's refreshing after so many incompetent fools I've had bill me $$$ for poor-quality work.
1969 Chris Craft Roamer 46 Refit: V-berth Bed Surround Padded Headliner
Cheers,
Q
