Pin Router PSI screwup
I didn't read the PSI warning when putting my new overarm router together. The 1/4" hoses blew out and worse, the router is jammed in the down position. Disconnectiong the air does not unjam the ram. What steps do I need to take to fix it?
- Ed in Tampa
jameshuling wrote:I didn't read the PSI warning when putting my new overarm router together. The 1/4" hoses blew out and worse, the router is jammed in the down position. Disconnectiong the air does not unjam the ram. What steps do I need to take to fix it?
PSI warning??????
I wasn't aware the overhead pin router used compressed air?????
Can someone explain this to me?
