New Product
Re: New Product
jsburger wrote:
delong94 wrote:Anyone have any comments on the new Cross-cutter?
http://www.shopsmith.com/ownersite/specials/7DV082.htm
It looks like the Microgig Matchfit. $15 more but all metal so that is the difference.
http://www.microjig.com/products/dado-stop/
http://www.microjig.com/product/matchfit-dado-stop/
I have the Microjig Matchfit and it works extremely well. The SS jig has micro adjustment that the Microjig does not. Looks to me to be a great new item.
After looking at the SS jig I see that it does not have three projections/feet/studs like the micro jig dado-stop. I saw the 3 studs on the SS web page but didn't realize it only held two and the third one was just a different length to replace one of the other two. As such it will not cut dados as the micro-jig does. However it is still a great product and worth the price for what it does. I will order one for sure.
Re: New Product
So add a fixed stop between the two adjustable ones. ;) Preferably removable for other operations.
dynabase
Re: New Product
Post by dynabase »
This homemade tool seems to do the same thing. Am I missing something?
https://www.youtube.com/watch?v=fNZWlLP ... gest-vrecs
I'm not saying anything bad about the new SS tool. I am asking a legitimate question. They seem to do the same thing. What am I missing?
Re: New Product
You missed nothing.
This one is a bit 'fancier'.
https://www.youtube.com/watch?v=YsfOWa_TFR8
masonsailor2
Re: New Product
Post by masonsailor2 »
The concept of the kerf setter has been around for many years. My father had one in his cabinet shop and I believe it was made by Craftsman or Stanley. It was made of brass and was very high quality. My brother inherited all his tools and I just sent him an email to see if he can locate it just for grins. It would have been made in the early 50's I believe unless it was a pass on from my grandfather which potentially could make it much earlier. For me I will probably use the SS version in the opposite mode as a micro adjuster for the rip fence to advance it accurately in small increments much like using the adjustable stop collar in DP or shaper mode to advance the table and fence. I have been wanting to make something of that sort for a long time but when the Incra fence system came out it sort of put it on the back burner. Should be a nice addition.
Paul
Re: New Product
JPG wrote:So add a fixed stop between the two adjustable ones. ;) Preferably removable for other operations.
Yes and very easy to do. Just drill and tap a third hole. You already have 3 studs.
Re: New Product
I think I understand the reason for the longer bolt but I do not understand the confusion over using the tool for both cross cutting without being against the rip fence AND using it to facilitate adjustable dados.
There is no need, however, to explain. I have ordered one and will know for sure how it works once it arrives. I am disappointed that it is yet to be shipped. The online status says that it will ship within a few days. Being a brand new offering, I thought that it would ship the next business day.
Re: New Product
I do not think there is any 'confusion' other than that we have extrapolated it's intended function(S) to include the features of other dado setting devices. Much of this thread is dealing with that.
sehast
Re: New Product
Post by sehast »
That has happen to me several times now within the last year or so. I think they must have a new policy of not carrying any inventory regardless of the part. Anyway I have grown to expect delivery in no less than two weeks and then be pleasantly surprised if it arrives earlier.
Re: New Product
dusty wrote:I think I understand the reason for the longer bolt but I do not understand the confusion over using the tool for both cross cutting without being against the rip fence AND using it to facilitate adjustable dados.
Well I will explain anyhow for those that want to know. The SS jig will certainly do adjustable width dados. But you still have to tweek them to the proper width. With the micro-jig you use the actual piece you want to fit in the dado to set the dado width. It makes for a perfect fit and you don't need a dado blade and try to get it to the correct width with shims and multiple test cuts.
