Trying to get my mid 80s mark v 510 running
Jobstchris
Post by Jobstchris »
How’s it going I just recently got my opas “grandfathers” mark v it has sat for many years when I turn it on it sometimes will turn then stop n the motor just hums or spindles will not turn at all my speed control also seems to be stuck I had previously followed the owners manual n did oil it and blow it out and made sure shives were not stuck anyone one who can take the time n help me threw this process is greatly appreciated I would like to get this to how my opa had it running back when he was alive thank you 🙏
Jobstchris
Re: Trying to get my mid 80s mark v 510 running
Any ideas or helpful insight on how to go about this
everettdavis
Post by everettdavis »
Jacob Anderson is one source for some free YouTube videos on repairing them. He also is a reputable repair site if you need someone to do it for you.
I would start here https://jacobshopsmithrepair.com/youtube-videos/
How things should look video is a foundation to build from.
Everett
Jobstchris
Thank you very much I will take a look and hopefully get in touch with him
garys
Post by garys »
Does it turn freely by hand with no power applied? If not, you have something bound up inside. If it turns, then look at the motor.
Jobstchris
Yes it turns freely I think the belt is slipping way to far between the sheaves
Jobstchris
I also checked the motor n tested with no belt on n it ran fine sounded good
Did you oil BOTH movable sheaves(control&floating)?
beeg
Post by beeg »
How wide is the belt?
everettdavis
beeg wrote:How wide is the belt?
As he asks, if it is less than 1/2" across the face, the belt should be replaced. You can read one of a number of discussions about this in reading the post http://www.shopsmith.com/ss_forum/viewt ... 28#p247928 and reading through that thread.
Everett
