THANK YOU µsoft [HELP]
Re: THANK YOU µsoft [HELP]
Well put!
- rjent
This is a convoluted way around this, but it will work.
I am assuming a couple of things, the main one is NTFS file system is assumed.
Go download a free imaging program called: Macrium Reflect.
https://www.macrium.com/reflectfree
It is an Hard Disk imaging program designed to disk imaging whole drives for backup/archive (ask if you need a definition). Once imaged (on another drive .. I use portable USB mounted multiple terabyte drives) you can "mount" the image as a virtual drive with the option of overriding the password protection giving you full access to all the files.
Let me know or PM me....
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
1951 jigsaw X 2
He is already past that by having a Linux partition on the drive. Linux can read the Windows data so no more work is needed to recover the Windows files even if the Windows installation was corrupted. It is simple work to just copy the files.
But, he corrected the problem with Windows so he no longer needs to recover any files.
AHHHH but 'he' needs to create a backup asap. This provides an interesting method.garys wrote:He is already past that by having a Linux partition on the drive. Linux can read the Windows data so no more work is needed to recover the Windows files even if the Windows installation was corrupted. It is simple work to just copy the files.
Thanks Richard!!!!
- rjent
You are welcome Let me/us know how it worked ...JPG wrote:AHHHH but 'he' needs to create a backup asap. This provides an interesting method.garys wrote:He is already past that by having a Linux partition on the drive. Linux can read the Windows data so no more work is needed to recover the Windows files even if the Windows installation was corrupted. It is simple work to just copy the files.
Thanks Richard!!!!
Dick
1951 jigsaw X 2
1951 jigsaw X 2
Gotta 'select' the bu gizmo. $$$$$rjent wrote:You are welcome Let me/us know how it worked ...JPG wrote:AHHHH but 'he' needs to create a backup asap. This provides an interesting method.garys wrote:He is already past that by having a Linux partition on the drive. Linux can read the Windows data so no more work is needed to recover the Windows files even if the Windows installation was corrupted. It is simple work to just copy the files.
Thanks Richard!!!!
- rjent
There is a free version on the link I sent you. I will email you an installer for the free one. What OS are you running? If you have an earlier machine (lap or desk) with xp or 7 on it that will work.JPG wrote:Gotta 'select' the bu gizmo. $$$$$rjent wrote:You are welcome Let me/us know how it worked ...JPG wrote:
Thanks Richard!!!!
Dick
1951 jigsaw X 2
1951 jigsaw X 2
I got the free version software. Tis the thingie that plugs into the usb port that I now need.rjent wrote:There is a free version on the link I sent you. I will email you an installer for the free one. What OS are you running? If you have an earlier machine (lap or desk) with xp or 7 on it that will work.JPG wrote:Gotta 'select' the bu gizmo. $$$$$rjent wrote:
W10 remember is what started this thread.
If you already have a Linux partition on that drive, could you not just boot up in Linux, mount the windows partition and copy the files to a different drive. No usb stick required.
Think USB DRIVE!!!rpd wrote:If you already have a Linux partition on that drive, could you not just boot up in Linux, mount the windows partition and copy the files to a different drive. No usb stick required.
