Carriage dimensions - 500 vs 510/520
wvthomas
Post by wvthomas »
Have a model 500 and wondering what is the distance between the 510/520 table support tubes? I'm wondering if it will clear the front shelf?
DLB
Re: Carriage dimensions - 500 vs 510/520
Post by DLB »
15-1/2" center to center, so 14-1/4" between them on 510/520. I'm not sure what you mean by front shelf.
wvthomas
Post by wvthomas »
Thanks DLB! I have a modified version of the accessory shelf, mounted between the legs.
garys
Post by garys »
If the accessory shelf has been modified, it should be quite easy to "unmodify" it back to factory specs so things fit.
