phone  (937) 890-5197
Shopsmith Forums
%nbsp;
11 posts 1 2
Wood Hardener
#260155 by moggymatt » Mon Jun 03, 2019 9:42 am
Anyone ever use a wood hardener on soft or punky wood? I saw Bondo and Verathane brands on the shelf this weekend and made me wonder.
Paul B
Re: Wood Hardener
#260160 by Hobbyman2 » Mon Jun 03, 2019 11:27 am
https://www.youtube.com/watch?v=9rDGhL_Tu3M
I have not personally used it
https://www.youtube.com/watch?v=1Cy1M4w3Mfk
Re: Wood Hardener
#260167 by john_001 » Mon Jun 03, 2019 2:35 pm
I've used Minwax Wood hardener. It seems to work pretty well. Wood soaks it up like a sponge and it hardens the wood into a kind of plastic. It's expensive - about $10 a pint, and a pint doesn't go very far. It's also very volatile; you want to use it outdoors if possible. You have to wear gloves - if you get it on your hands, it's worse to get off than Gorilla glue, if you know what that means!
Re: Wood Hardener
#260174 by benush26 » Mon Jun 03, 2019 4:31 pm
I’ve used Cactus Juice with good success, but it’s also very pricey at over $100 per gallon! 😱. A friend and I bought a gallon for a few projects we were working on. Mine was birch which had dried for a couple years and was beginning to get powdery. It soaked up large quantities! I also used it on some ash with limited success. It could be that I didn’t let it soak long enough or the ash was so dense that not as much soaked in as I would have liked.
Good luck.
Be well,
Ben
Re: Wood Hardener
#260181 by ChrisNeilan » Mon Jun 03, 2019 7:52 pm
benush26 wrote:I’ve used Cactus Juice with good success, but it’s also very pricey at over $100 per gallon! 😱. A friend and I bought a gallon for a few projects we were working on. Mine was birch which had dried for a couple years and was beginning to get powdery. It soaked up large quantities! I also used it on some ash with limited success. It could be that I didn’t let it soak long enough or the ash was so dense that not as much soaked in as I would have liked.
Good luck.
Be well,
Ben
Did you use a vacuum chamber? Makes a huge difference!.
Chris Neilan
Re: Wood Hardener
#260212 by davebodner » Tue Jun 04, 2019 3:06 pm
I've tried the Minwax wood hardener with limited success.
Better for me was removing the bad stuff and filling in with epoxy-based wood filler. I've also thinned the epoxy stuff with acetone to apply it like spackle. I might've even thinned and applied regular epoxy that way, if I could only remember.
Re: Wood Hardener
#260213 by benush26 » Tue Jun 04, 2019 4:07 pm
I don’t have one, but have seriously considered making one to use with Alumilite.
I guess that the vacuum chamber is going to be bumped up on the list. CL had a paint pot for $25 but I’ve been looking at YouTube and figure I can build one from 3/4” plywood scraps. I have a couple handles I make that are too big to fit in a standard 5 gallon paint pot.
Thanks for the tip!!! It’s ironic that I flinch at the cost of the Cactus Juice, but am willing to pay extra for Alumilite, though I’m not certain it’s any better than the cheaper stuff.🤔. I thought old age was supposed to bring greater wisdom. Maybe it skipped me!😱😂
Be well,
Ben
Re: Wood Hardener
#261028 by ChrisNeilan » Tue Jul 09, 2019 11:33 pm
Be well,
Ben
For Alumalite you need a pressure pot, not vacuum. The pressure compresses any air bubbles to the point of being too small for the eye to see.
Chris Neilan
Re: Wood Hardener
#261057 by masonsailor2 » Thu Jul 11, 2019 10:26 am
The concept has been around for many years. We used the WEST ( wood epoxy saturation technique ) system on plywood and solid wood for boats back in the 70’s. Now they have much safer methods using polyurethane but the concept is the same. You use the wood essentially as a mold to produce a block of resin or in the case of plywood to create a very stiff and waterproof component for a boat. It does add quite a bit of weight to the wood component though.
Paul
Re: Wood Hardener
#261066 by benush26 » Thu Jul 11, 2019 2:44 pm
Interesting! I’ve just made pen blanks in flexible forms using the Alumilite and hadn’t used any pressure device. I’ve not noticed any bubbles, but that doesn’t mean there weren’t any, just that I hadn’t noticed or had to deal with them. I don’t stir very vigorously and add the colors and flecks without much speed. Maybe that has helped reduce them. A friend uses a repurposed paint pot and has offered to let me use it. From now on, I’ll use it until I buy one.
About to try turning a few vases using Alumilite and kiln dried Russian Olive (LOTS of cracks to fill with colored acrylic). I hadn’t planned on using a pressure pot, but I’ll have to try it. I assumed (incorrectly 😱) that I would need to vacuum out any air pockets, but now with your wise advice, I’ll change plans.
As with too many projects, I’ve guess I’ve been lucky that my lack of knowledge hasn’t blown up (literally) in my face.
I do like exploring avenues from the tried and true wood working, but have so much to learn.
Thanks for the information!
Be well,
Ben
Who is online
Users browsing this forum: Google [Bot] and 109 guests
Subscribe to our mailing list
* indicates required
