This Top Quality Shopsmith NOVA Lathe Chuck Gives You a Solid Grip On Many Types of Lathe Projects – and Makes Quick Work of Attaching & Detaching Turnings
uploads - g3_ss_special_offer
uploads - g3_ss_pkg_l
Manufactured Exclusively
For Shopsmith
Special Offer – Includes
Shopsmith Insert Adapter
& Bonus NOVA Pin Jaws
Exclusive Package Offer — Only From Shopsmith
uploads - tbar_and_wormwood_screw_l
Precision machined to the closest tolerances from the highest quality steels, this premier quality, self-centering scrolling chuck allows you to attach and detach your turnings without leaving unsightly screw holes or having to glue scrap blocks to them that can be difficult to remove.
A quick turn of the geared, T-Handled Wrench moves all four jaws smoothly and in unison to grasp your workpiece firmly. Other chucks use jaw profiles that are engineered to grasp hard materials such as steel or rounded profiles… and often crush the wood fibers without digging in to hold the stock securely. The unique NOVA dovetail jaw profile, however, is carefully designed to hold the wood firmly without crushing it.
You can count on a secure hold, whether you’re gripping end grain or side grain… and feel confident that your gripping pressure will be spread over a wide area, helping to prevent damage to your workpieces.
Includes SafeLock Woodworm Screw and a special Shopsmith Insert Adapter
The 1.889″ long by 0.507″ diameter screw offers a deep, fine thread that is precision machined all the way to the end of the screw, allowing it to lead easily into a 9/32″ diameter pilot hole in soft woods (5/16″ for hardwoods) and grip tightly. It features a square shank and locating groove that locks positively into the NOVA chuck body.
The Insert Adapter is also precision machined to close tolerances from high strength carbon steel. It features a wide mounting face to eliminate wobble and is designed specifically for attachment to the 5/8″ diameter Shopsmith spindle with your standard 5/32″ allen wrench.
uploads - pin_jaws_l
Includes $54.99 Value Pin Jaws
$54.99 Value Pin Jaw Set enhances your turning capabilities
This jaw set is designed to expand into a pre-bored hole in your workpiece. This makes it the ideal choice for turning bowls with free form edges. However, unlike pin chucks, which typically only work in a single sized hole, these jaws will grip a range of different hole sizes, so you won’t have to bore an exact sized mounting hole with this set.
The long jaws can be used to provide a powerful, more stable external (contraction) grip when turning miniature or smaller diameter spindles… or for those times when you need to use an internal (expansion) grip on smaller diameter bowls, turned boxes and similar projects. It’s included with your G3 purchase !
ChuckExpandingContracting (External Gripping Action)
(Internal Gripping Action)Square ModeSpigot Mode
MinMaxMinMaxMinMax
G32.008″2.835″1.220″2.047″1.654″2.520″
Pin Jaws1.024″1.811″0.278″1.102″0.394″0.748″
Features:
  • Quality Materials and Precision Machining (body made from precision machined 1045 high tensile steel)
  • Common Accessory Jaw Fixing Profile – compatible across all NOVA chucks and accessories
  • High Tech Precision Composite Jaw Slides
  • Special Woodturning Dovetail Profile on Jaws
  • Auto Safety Stop Feature – Jaw slides can’t protrude past the chuck body
  • Open back for easy cleaning
  • Comprehensive Instructions
  • Common Insert/Adaptor Fitting – compatible across all NOVA chucks
  • Safe Lock™ Woodworm Screw
Includes: Shopsmith NOVA G3 Chuck • Pin Jaw Set • Shopsmith Chuck Adapter • 50mm Jaw Set • Fasteners • T-Bar Handle • Woodworm Screw • Instructions
Owners Manual: NOVA G3 OWNERS MAUAL – PDF
A Top-Quality, Highly Versatile Lathe Chuck System at a Great Value !
Manufacturer’s suggested retail price for this package (including NOVA G3 Lathe Chuck, Pin Jaws, and Shopsmith Insert Adapter) is $289.00. Yours Now At a Special Package Price!
Check Out the NEW! NOVA Pro-Tek Reversible Lathe Chuck Kit!
uploads - nova g3 pro tek chuck
NEW! NOVA PRO-TEK REVERSIBLE LATHE CHUCK KIT
The NEW! NOVA Pro-Tek Chuck offers new features including Nickel-Plating for Rust Prevention, Laser-Etched Jaw Identification, 3 Standard Jaw Sets which includes 50 mm Serrated Jaws for added versatility, 2 T-Wrenches, Torx-Drive Jaw Mounting Screws, and More!
Order on the Web or by Phone, if you prefer — (937) 890-5197 .
Call before Eastern Time
