Save 15% on everything you need! SAVE NOW
1/2 Inch Mortising Bit and Chisel
521884
$44.95
$38.21
SAVE 15%
Use these Sturdy Mortising Bits to produce an Heirloom Quality Guifts that will last for Generations.
A mortising bit will allow you to drill square or rectangular holes in a piece of wood. This can be used to create a tenon joint. Precision ground to produce sharp, clean square holes and mortises.
� 1/2 Inch Mortising Bit and Chisel (521884)
� 3/8 Inch Mortising Bit and Chisel (521883)
� 1/4 Inch Mortising Bit and Chisel (521882)
Other mortising parts:
Mortising Hold Down Assembly (521900)
Attaches to the Rip Fence of your MARK V (Model 500, 510 or 520) to keep your workpiece from lifting when the Bit/Chisel set is withdrawn.
Mortising Hold Down Foot (50377201)
Hold Down Foot. Mounts on Hold Down Rod on Rip Fence
Mortising Attachment (521901)
Attaches to your MARK V's Quill to hold and prevent the Mortising Chisel form turning while the bit inside removes the majority of the stock from the mortise.
Mortising Chisel Honing Stone (521902)
Hollow chisel mortising requires a great deal of downward pressure to shave the sides of the mortise smooth and true. That's why it is extremely important that all four edges of the hollow chisel be kept as sharp as possible. This precision-ground stone has been made specifically for this purpose. The Mortising Chisel Honing Stone is a 50-degree stone for your 1/4", 3/8" and 1/2" chisel.
Note: If you own an older model (pre-2000) Mortising System, you'll need to order either 513549 or 513550 to fit the angles of your older mortising chisels.
Mortising Chisel Honing Stone (Red) (513550)
If you own a Pre-1990 Mortising System. For 1/2" mortising chisels 46.5 degree stone.
Mortising Chisel Honing Stone (White) (513549)
If you own a Pre-1990 Mortising System. For 1/4" and 3/8" Mortising Chisels 41-degree stone.
Slot Mortising Package (555372)
Easily make strong accurate mortise and tenon joints with the Slot Mortising Package. Use your Speed increaser or Under-Tale Routing to make the mortises and tennons.
Includes: 1/4", 3/8" and 1/2" carbide tipped straight router bits, all with 1/2" shanks for rigidity, 1/2" Router Chuck with Shield and the Tenon Master Jig.
Specifications
(1) 1/2 Inch Mortising Bit and Chisel
