Save 15% on everything you need! SAVE NOW
1/2 Inch Premium Combination Bandsaw Blade
555196
$34.95
$29.71
SAVE 15%
Shopsmith Premium Bandsaw Blades are fabricated from high-quality silicon carbide steel with precision-milled teeth for superior, long lasting performance. Our premium bandsaw blades are induction heat treated to ensure an even hardness. Shopsmith blades feature a special tooth set and rake angle ensuring consistent cutting with less pressure on a wide variety of materials reducing heat build-up, prolonging blade life. All Shopsmith Premium Bandsaw Blades include a lifetime warranty on weld integrity. Should your bandsaw blade break at the weld, we'll replace it for free for the lifetime of the blade. Shopsmith's 1/2 Inch Premium Heavy-Duty Combination Blade features a 6 TPI, raker-style tooth set for all-purpose cutting of wood, plywood, and plastics up to 6 Inches thick, and non-ferrous metals up to 1/2 Inch thick. This blade has a 2 Inch minimum radius.
Specifications
