top of page
Lathe 6 Inch Cast Iron Face Plate
SKU 505591
505591
Original price
$54.95
Sale price
$46.71
SAVE 15%
Shopsmith Cast Iron Lathe Faceplates provide secure, smooth-running support for turning large or small diameter bowls and similar objects. Our 6 Inch Cast Iron Lathe Face Plate attaches quickly to the spindle of any MARK model with a single setscrew. The 6” diameter diameter face plate is recommended for large diameter bowls, platters, trays, plant stand tops, and similar projects. This faceplate arrives dynamically balanced for vibration-free performance. The inner set of three 1/4” diameter mounting holes can be used to grip workpieces down to 2-3/8” in diameter the middle set down to 4” in diameter and the outer set down to 5-1/2” in diameter. Each set of holes is off-set slightly so that if you need to remove the turning block from the faceplate, it only goes back on the faceplate one way.
No Reviews YetShare your thoughts. Be the first to leave a review.
Frequently Bought Together
bottom of page
