top of page
Shaper Guard Upgrade
SKU 555140
555140
Original price
$87.96
Sale price
$74.77
SAVE 15%
Shaper Complete Package (for All MARKs except MARK V 500) (555141) \nCreate Decorative Edges, Fancy Trim and Precision Joinery with This Professional Shaping Package \nWhile the molder produces great straight-line cuts in the surfaces of workpieces and the dado is the tool to reach for when you need square-edged dadoes or grooves, the shaper is best for decorating edges or making edge joints on straight or curved edges. \n \nIn fact, rub collars and starting pins let the shaper tackle irregular shaped edges as easily as regular ones. Plus, the shaper even lets you work on the inside edges of cut-outs such as round or oval picture frames. \n \nIncludes: Shaper/Drum Sander Fence Kit � Shaper Table Insert � Shaper Arbor with Collars � 1/4" & 1/2" Combo Quarter Round Cutter � Flute & Quarter Round Cutter � 3/16" Bead & Cove Cutter � Door Panel Shaper Cutter � Door-Rail Coper Shaper Cutter \n \nNote: 555141 is Not for use with 10-ER, Mark 2 or older-style Mark VII, or MARK V 500. \n \nShaping Complete Package is available and is sold separately for MARK V 500 (556209) \n \nGet Precise Lateral Depth-of-Cut Control With the Shaper / Drum Sander Fence Kit (555113) \n \nBoth the infeed and outfeed sides of this fence are independently micro-adjustable to 1/64". It provides full workpiece support before and after the cut. \n \nIncludes: \n� Shaper/Drum Sander Fence \n� Shield \n� Quill-Mounted Feather guard \n� Table-Mounted Featherboard \n� Vacuum Attachment. \n \nNote: Not for use with 10-ER, Mark 2 or older-style Mark VII or MARK V 500. \n \nShaper / Drum Sander Fence Kit is available and is sold separately for MARK V 500 (555144) \n \nThe Under-Table Shaper Starter Kit is the perfect partner with your Double-Tilt! (555149) \nGet started quickly and easily making beautiful decorative edges on all your projects. Decorative edges greatly enhance the look of the finished piece. Under-Table Shaping operations are generally considered safer as the workpiece acts as an additional safety guard. It also is considered more convenient and accurate for decorative cuts because you can inspect the workpiece without changing the set-up. It can be used with any MARK that has the Double-Tilt capability. \n \nThe Under-Table Shaper Starter Kit is a great option for Owners looking to try under-table shaping for the first time, or who need to replace lost or worn parts of their Complete Shaping Package. MARK 7 / MARK V 520, 510, 505 / MARK 4 \n \nYour Shaper Starter Kit includes: \n� Shaper/Router Safety Shield \n� 1/2" Shaper Arbor with Collars \n� Shaper Table Insert (fits all MARKs except MARK V 500) \n� Ogee Shaper Cutter \n \nShaper/Router Guard Upgrade for Kit (555140) \nAdd safety and improve dust and chip removal with the Shaper/Router Guard Retro-Fit Kit. Designed specifically for your Mark V in the shaping and routing configurations for improved dust and chip removal and increased shop safety on any Routing or Shaping packages purchased before 1/86. Works on All MARKs \nShaper/Router Guard Upgrade for Kit Includes: Feather Board Guard, Vacuum Attachment, Circular Shield & Brush, Feather Board, & Rear Fence Guard. \n \nRip-Fence Featherboard - Attaches to the top of your router table fence for use as a hold-down during straight-line routing. (555783) \n \nBUNDLE AND SAVE \nBall Bearing Shaper Spindle & Chuck (556270) \nShaper Spindle with Ball Bearing Rub Collars and 1/2" Router Chuck. Works on all MARKs \n \nShaper Spindle Arbor Set - Ball Bearings (555472) \nProvides improved finish cuts on both straight line and contour Shaping; burn-free results. \nFor use with the Speed Increaser (If you already own.) As well as with the �� Router chuck to hold Shaper Cutters. Works on all MARKs \n \nIncrease the Functionality and Convenience of Shaping with these Accessories \n \nRouter / Shaper Table-Mounted Guard (515704) \nOverhead Shaper Guard - Use with the Under Table function of your MARK 7 / MARK V 505,510,520 / MARK 4 for contour Shaping or using Router Bits with bearing pilots. Position this Overhead Shaper Guard directly over the cutter for maximum coverage. Comes with adjustable brush on clear guard to knock down flying chips and shavings for more effective dust collection. Support Bracket comes with integral dust port. This assembly slips in the table T-Slot and locks in place with a quarter-turn of the support post. \n \nIncludes: \n� See-Through Guard \n� Screw-In Mounting Post \n� Support Bracket with Integral Dust Port \n� Mounting Hardware \n� Instruction Sheet \n \nShaper/Router Shield Puts Safety Back Into Shaping and Routing (555373) \nThis see-through shield clamps around your MARKs quill housing with a single screw and provides both front eye protection and a rear brush that can be adjusted to meet the top of the fence or your workpiece for added dust collection efficiency. Standard with router and shaper packages. \n \nNote: Not for use with 10-ER, Mark 2 or older-style Mark VII or MARK V 500. \n \nShaper Table Insert (for MARK 7 / MARK V 520, 510, 505) is a Must for Full Workpiece Support for Shaping (555122) \nMARK 7 / MARK V 520, 510, 505 / MARK 4 table insert is made of rigid diecast aluminum (Mark V model 500 insert is made of a tough polymer). This Table insert has a 2-1/4" diameter circular cutout to allow the shaper cutter to drop below the table surface to shape edges completely and smoothly. Two threaded holes for screw-in starter pins from the top and as a provision for attaching vacuum attachment for dust collection. \n \nShaper / Drum Sander Table Insert (for MARK V 500) (556267)
No Reviews YetShare your thoughts. Be the first to leave a review.
Frequently Bought Together
bottom of page
