top of page
Sharpening Guide Package
SKU 555193
Price
$124.99
Sharp lathe chisels are essential for turning bowls or spindles, but can be challenging to sharpen and get that precise cutting edge. We've eliminated the guesswork by developing a guide that lets you put a super sharp cutting edge on all your chisels - lathe and bench types. The Sharpening Guide mounts on any MARK table system and has been specially designed to give you a variety of preset angle settings for skew chisels, gouge chisels, round nose chisels, parting tools, bench chisels and even shaper cutters.
The Sharpening Guide is lightweight, yet extremely durable. In addition to the preset angles, you have adjustable angle settings that give you a personalized bevel to meet your individual needs. You can mount the Shopsmith Sharpening Guide on your MARK worktable for sharpening bench chisels and shaper cutters, and lathe chisels before you start turning OR on the extension table for sharpening lathe chisels even while turning without breaking down the lathe. In every case, the guide will help you achieve the perfect edge on cutting tools, giving projects requiring cutting a professional look.
The comprehensive owner's manual tells you how to mount your guide on your MARK.  The full-size drilling template shows you exactly where to drill mounting holes in your extension table. And it gives you many tips and techniques that will allow you to get the most out of your sharpening guide. Order your Shopsmith Sharpening Guide or package now and discover the big difference that really sharp chisels can make.
Complete Shopsmith Sharpening Guide Package Includes:
  • Sharpening Guide
  • 12-inch Steel Sanding Disc
  • 12-inch Cloth-Backed Sandpaper (three pieces, 150 grit aluminum oxide)
  • Owner's Manual
Note: The Shopsmith Sharpening Guide is specifically designed for the Shopsmith 5 Piece Lathe Chisel Set that was sold through 2016. For other lathe chisels, you may want to consider the Strip Sander Chisel Sharpening Attachment.
Reviews
Rated 4 out of 5 stars.
Based on 1 review
1 review
  • klaye210Oct 09
    If you turn, you need this jig
    There may be other jigs out there that work as well but this one is simple and it works well with the ShopSmith.
    Was this helpful?
Frequently Bought Together
bottom of page
