Jointer
$699.95
Jointers have many great uses, including flattening, straightening and truing-up project pieces.
Jointers are used to smooth and square board edges in preparation for glue-up into wider panels perfect for cabinet and furniture projects or any woodworking project.
Loaded with work-saving, results-enhancing benefits and accessories! As with all Shopsmith special purpose tools, your Jointer offers a number of great features and accessories to help you make everything you make - better.
- Bevel or Chamfer Edges - Create smooth, precisely beveled or chamfered edges on boards for angled cabinetry; making decorative interior or exterior columns; creating a bowl or vase glue-up for lathe turning; or cooperage (barrel/container-making) projects. No sanding required!
- Eliminate Cupping - Boards are often cupped or hollow on one side. As long as they're no wider than 4", you can eliminate this cupping with a few light Jointer passes. This will change board thickness.
- Square Large Stock - Squaring large stock on a table saw can often tax its capabilities, especially with resinous woods. Use your Jointer to deliver a perfect 90� angle on stock up to 4" thick every time. No sanding required!
- Form Precision Edge Rabbets and Tongues (up to 3/8" deep) - Form a perfect, 90� rabbet or tongue (for tongue-and-groove joints) along the edge of a board with your Shopsmith Jointer. No sanding required!
Safety Feather Guard Special Guard is spring-loaded to exert continuous pressure against the workpiece, forcing it against the fence while you make your cuts. To increase or decrease tension, just loosen the tension adjustment Knob, move it along its adjustment arc and tighten.
Simple Knife Leveling and Clamping System Your Shopsmith Jointer's individual knife leveling screws let you adjust each knife end up-and-down individually to compensate for variations created during sharpening. As a result, you'll be able to sharpen your own knives using our special Planer/Jointer Knife Sharpener, without the need for costly professional match-grinding.
Full Tilting Fence The fence on your Shopsmith Jointer tilts up to 45� left or right and offers adjustable auto-stops at common angles for rapid adjustment convenience.
Built-In Dust Collection Chute Built-in 2-1/2" dust collection chute helps you capture the dust and debris before it gets into the shop environment.
Mounts on MARKs, Power Stand or Power Station.
The Shopsmith Jointer is the best value for smoothing, straightening and squaring project components!
Specifications
� Maximum Width of Cut - 4"
� Maximum Depth of Cut (Single Pass) - 3/8"
� Maximum Depth of Rabbet Cut - 3/8"
� Infeed Table - 5-1/2" x 13-1/4"
� Outfeed Table - 4-1/2" x 13-1/4"
� Overall Table Length - 28"
� Fence - 3" x 21-3/4"
� Fence Tilt - 45� left to 45� right
� Fence Auto-Stops (Adjustable at) - 45�, 90� and 45�
� Cutterhead Diameter - 2-1/2"
� Knives - 3 Precision-Ground Steel
� Bearings - 2 Sealed, Ball Bearings
� Speed (Recommended) - 3,900 - 6,200 rpm
� Weight - 53 lbs.
