phone  (937) 890-5197
Shopsmith Forums
%nbsp;
24 posts 1 2 3
Re: Incra Miter Gauge
#222210 by reible » Sat Oct 08, 2016 11:25 am
I guess I'm not sure what features you are looking for in a miter gauge. Shopsmith as well as Incra sell the V120 which has some pretty good specs and has 1 degree positive stops. If you get it from shopsmith you have the option of Shopsmith Safety Grip handle. That is a real plus in my book.
http://www.shopsmith.com/ownersite/cata ... rav120.htm
Now as far as added features you can add the incra Telescoping Flip Fence like this one:
http://www.incrementaltools.com/INCRA_T ... c18-31.htm
So again while I'm not sure what features you are looking for there are incra options that might well serve your needs.
If you are looking for a better fit in the miter slot then incra is the way to go. With adjustment there is no play.
If you have other needs well then there are other options above and beyond this that don't require milling a miter bar. Of course if you are bound and determined to mill a miter bar then feel free, just wanted wanted you to know about these other options in care you didn't know.
#222285 by lalkie01 » Sun Oct 09, 2016 8:30 pm
I do have a milling machine and should be able to mill it to the right size. It looks difficult to adjust the nylon slide screws. Has that caused you any problems? Thanks Larry
#222289 by Gene Howe » Sun Oct 09, 2016 8:58 pm
No problems whatsoever, Larry.
#222344 by lalkie01 » Mon Oct 10, 2016 9:42 pm
Thanks again. I about decided to stay with the shopsmith miter gauge as I am getting real close using it and a starrett combination square. I think I am going to get the nova chuck from Shopsmith as I don't have enough money for both. Larry
#222352 by Gene Howe » Tue Oct 11, 2016 7:50 am
Thats a good decision, Larry. The Shopsmith gauge is very adequate.
#223271 by ecom1 » Mon Oct 31, 2016 4:34 pm
If you're just looking for "standard" angles, this might be an option for you.
https://miterset.myshopify.com
Shopsmith: 2 Mark V 510 (1988,1993), bandsaw, jointer, mounted planer, belt sander, scroll saw, strip sander, lathe duplicator, conical disc sander, biscuit joiner, free standing router table with Jointech IPM-1 plus original Incra jig
Other stuff: Cman 10" RAS, Ridgid 13" planer, Makita contractor saw, Rikon drill press, Delta BOSS, Dremel scrollsaw, routers, drills, and other toys
#223285 by jsburger » Mon Oct 31, 2016 8:31 pm
ecom1 wrote:If you're just looking for "standard" angles, this might be an option for you.
SS sells it for the Shopsmith. :confused:
#223297 by ecom1 » Tue Nov 01, 2016 3:54 am
Thanks John - I was sure I saw it on the SS website first, but couldn't find it again.
#223299 by dusty » Tue Nov 01, 2016 5:46 am
Is this what you saw?
http://www.shopsmith.com/ownersite/catalog/miterset.htm
#223317 by ecom1 » Tue Nov 01, 2016 5:17 pm
That's it - thanks Dusty! Has anyone tried this - looks like a simple but effective idea.
Who is online
Users browsing this forum: No registered users and 28 guests
Subscribe to our mailing list
* indicates required
