I have to admit, when I first threw the switch on my Shopsmith saw I thought kickbacks were rare. I had no idea how important blade alignment, etc. was.
In one video I watched, it was mentioned that table saws are only for square pieces of wood. Granted, it seems to me that an EXPERIENCED operator could cut raw wood. But, a newbie trying to cut a mesquite limb was a bit much.
I've received some very good advice from this post and I thank you all. I've been reading and watching videos more than I would have had my kickback never happened. Thank God it was minor and not a finger removing event.
Small Pieces - Kickback
Re: Small Pieces - Kickback
Dean
Mark V 505
Mark V 505
Dean,dino9832 wrote: ↑Mon Jul 11, 2022 12:26 pm I have to admit, when I first threw the switch on my Shopsmith saw I thought kickbacks were rare. I had no idea how important blade alignment, etc. was.
Thanks. I hope the feedback from everyone was useful. By the way, welcome to the forum...Yeah, blade alignment is important for ripping safely, as well as for getting accurate cuts. The Shopsmith miter gauge is better than most in that it has a safety grip and clamp built in. Bottomline is you want to be, and feel, in control for any cuts that you make. The miter gauge should keep you safe for most all cuts of dimensional lumber, but as you found out it isn't as safe with a log or limb. Of course you could make a sled or just a "V" shaped cutout (as was mentioned) in a piece of lumber that the log could rest in for the cut. This could be used with the miter gauge to make that cut safer. Glad you are more aware of kickback, etc. now. Not sure if it is good or bad to get bitten by it early in your woodworking career, but hopefully now you know a bit more to look out for. Be mindful of the safety aspects, but also don't forget to have fun with this new tool.
RF Guy
More "Jazz".
Lack of control by the operator contributes to the possibly of kickback.
I consider(not a popular opinion) the use of push sticks etc. to be another contributor to lack of sufficient control.
There ARE times when push sticks etc. MUST be used, but we need to realize that adds another avenue for kickback to occur.
- edflorence
Very good point that a v-block cradle can be used with the tablesaw as well as the bandsaw. . . For sure, there are often many ways to get the job done.
The OP's issue was partly with the small size of the cut-off and it getting caught under the upper saw guard...therefore my suggestion that for this sort of cut perhaps the bandsaw might be the better way to go.
Idaho Panhandle
Idaho Panhandle
---------------------edflorence wrote: ↑Mon Jul 11, 2022 7:02 pmVery good point that a v-block cradle can be used with the tablesaw as well as the bandsaw. . . For sure, there are often many ways to get the job done.
+1 on using the right tool for the right job .
