I've been lurking here for years, and I would first like to thank everyone for all of the information I have learned over that time.
I recently rescued my Shopsmith from being buried in the corner of my garage, where it has been for years. I have Power Pro, Double tilt, 3" Casters, and lift assist upgrades to install. I'm thinking I should remove the headstock, flip it over and do the casters and double tilt, flip it back upright to put on the Power Pro, and then do the lift assist. Would a different order work better? Any suggestions would be appreciated.
Thanks,
Order of Upgrades
Welcome to the forum.
WOW, you come out of hiding with the whole enchilada to show us. Congratulations. Can't wait for the photos.
I don't have the double tilt or the PowerPro but I believe your sequence is logical.
FWIW, I installed the caster modification without turning it upside down. I made a wooden template (using the paper template provided by Shopsmith) and then used the wooden template to drill the holes in the legs. By doing this, I could bolt the template in place on a leg and then drill the the holes, move the template and drill more holes.
- camerio
- Location: Valcartier, just north of Quebec City, CANADA
Dusty, you should have posted the link to the thread with pictures that, if I recalled, you made about this ....dusty wrote: FWIW, I installed the caster modification without turning it upside down. I made a wooden template (using the paper template provided by Shopsmith) and then used the wooden template to drill the holes in the legs. By doing this, I could bolt the template in place on a leg and then drill the the holes, move the template and drill more holes.
Camerio
MarkV 520 & Band saw
- camerio
Mike, welcome to this wonderful forum !
You should upgrade you profile with your location, there may be a member or two in you area.
I have not been able to upgrade my 520 yet, but I am hoping Santa will be good to me so I can at least put some new wheels on ....
Nice of you to join us and if there is not any pictures, then it did not happened .... we like pictures ...
Camerio
OK.camerio wrote:Dusty, you should have posted the link to the thread with pictures that, if I recalled, you made about this ....
Here it is.
If you have the DIY PowerPro upgrade, you might consider removing the belt cover, motor, speed control, quill and drive sleeve before removing the headstock from the frame. Then the headstock casting will be ready for the upgrade once you remove the headstock lock. That is done with the headstock casting removed from the frame.Mike907 wrote:I've been lurking here for years, and I would first like to thank everyone for all of the information I have learned over that time.
Thanks,
Rob in San Diego
