Alternatives to biscuits?
I'd like to make the Build-to-suit Study Desk in the March 2013 issue of WOOD ( http://www.woodstore.net/bustde.html ) but it calls for biscuits.
I don't have a biscuit joiner or the $$ to get one.
What would be a good alternative for the joints?
Thanks!
Thanks!
Morgan
Blue Springs, MO
SS Mark 7 PP
Blue Springs, MO
SS Mark 7 PP
- Ed in Tampa
- BuckeyeDennis
Dude: I have got to believe that if you can afford a Mark7 PowerPro, you can swing a ShopSmith biscuit joiner. I just checked, and they are fetching between $50 and $100 on eBay. I think that I scored my own, in like-new condition, for a bit less. IMHO, and also according to the reviews, the ShopSmith joiner is just about the most versatile one around, IF you own a ShopSmith machine to mount it on.
I have no doubt that a $875 Festool Domino standalone biscuit joiner is very nice, but can you set it up precisely in five dimensions like you can a ShopSmith?
I was going to suggest cornbread.skou wrote:Man, I SO wanted to post, "buttered toast!"
But, biscuits DO taste better!:D
Seriously, I'd go with dowels, since the SS makes this
so easy.
steve
Heath
Central Louisiana
Central Louisiana
- terrydowning
I guess it's just me. I've never used a biscuit joiner and I do so little of that type of joining that I'v never had the inclination to purchase one. Are they really that much better?
For joining edge to edge I just use dowels and for angled joints I use on of three tactics:
Mortise and tenon the strongest and prettiest joint and if you're clever these can also made into knock down joints for dis-assembly and transport.
Dado or rabett joint with glue sometimes with dowels or screws if I want to over engineer something or spice up the finish with a dowel embellishment (you can't do that with a biscuit).
Butt joint. Use glue and dowels for semi permanent, no glue and screws for temporary or knock down joints.
Just how I do it. I also rarely use pocket screws and have no desire to purchase a jig. On the rare occasion I use pocket screws, I freehand them.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
"I also rarely use pocket screws and have no desire to purchase a jig. On the rare occasion I use pocket screws, I freehand them."
Your Shopsmith is itself a pocket screw jig. Put the fence on the table, tilt the table to the necessary angle, and drill. See Figure 7-33 in the online PTWFE.
http://www.shopsmith.com/academy/drillp ... .htm#angle
Gary
Gary
terrydowning wrote:I guess it's just me. I've never used a biscuit joiner and I do so little of that type of joining that I'v never had the inclination to purchase one. Are they really that much better?
I haven't used biscuit joiners a ton but seems they are much quicker then the joining options you mentioned and as I mentioned above, the slots are cut oversize lengthwise on each piece for the biscuit, so you have the ability to shift pieces laterally a bit as you glue them, so an easier and more efficient means to accurately join two pieces together. Certainly for making things like bookshelves and cabinets, they are far quicker means to make good, accurate joints. I have the SS biscuit joiner but haven't had a chance to use it yet, so I'm not sure how it compares to using your typical handheld unit. I've eyed the DeWalt handheld unit for a while now as it seems like it would be more versatile then one that mounts on the SS...I need to have enough consistent use for one before I can justify the new toy.
I recently bought a copy of "Best of Fine Woodworking - Power Tool Techniques" 2005 version, which was on sale for 75% at Taunton.com (I think it was $2.50 and free shipping). It has a great article on the basics of biscuit joining which is pretty helpful in assessing the pros/cons of using one.
