Does anyone have experience using the SS Lathe Duplicator with EWT (Easy Wood Tools) Cutter Inserts? According to EWT, their diamond cutter works, hoping others do as well...
Thanks
jack
www.thewoodshop.20m.com
SS Lathe Duplicator and EWT Cutter Inserts
- Bronze Member
Re: SS Lathe Duplicator and EWT Cutter Inserts
I have tried the turn master carbide cutters with my SS Duplicator. The hole size for the screw is a little bit bigger than the SS cutters but it worked fine. I picked it up at Woodcraft and other than being a little pricey I got very good results with it.
Paul
Paul
