top of page
1/4 Inch Premium Bandsaw Combination Blade (1/4x.025x6T)
SKU 555419
Price
$34.95
Shopsmith Premium Bandsaw Blades are fabricated from high-quality silicon carbide steel with precision-milled teeth for superior, long lasting performance. Our premium bandsaw blades are induction heat treated to ensure an even hardness. Shopsmith blades feature a special tooth set and rake angle ensuring consistent cutting with less pressure on a wide variety of materials reducing heat build-up, prolonging blade life. All Shopsmith Premium Bandsaw Blades include a lifetime warranty on weld integrity. Should your bandsaw blade break at the weld, we'll replace it for free for the lifetime of the blade. Shopsmith's 1/4 Inch Hooked-Tooth Premium Combination Blade is the standard OEM blade that comes pre-installed on all new Shopsmith Bandsaws. This blade features a 6 TPI, hook-style tooth set making it the perfect all-around bandsaw blade for even, consistent cutting of wood, plywood, plastics, and non-ferrous metals. This blade has a 3/4 Inch minimum radius.
Specifications
(1) 1/4 Inch 6 TPI Hooked Bandsaw Blade made from standard Carbon Steel
Loading…
Frequently Bought Together
bottom of page
