top of page
Bandsaw Cover Upgrade with Window and Dust Port
SKU 522221
Price
$99.95
The Bandsaw Cover Upgrade with Window and Dust Port allows you to tension the blade and see the blade tension scale when adjusting your blade tension without ever having to remove the cover. Simply insert the 5/32" Allen wrench through the side of the cover to make this adjustment. Then before storing, it is easy to reduce tension without ever removing the cover. The cover also has an arrow to take the guess work out of which way your blade should run.
Out of stock
No Reviews YetShare your thoughts.
Be the first to leave a review.
Frequently Bought Together
bottom of page
