Find Your Part
- Use the zoom tool, mouse wheel, or pinch to zoom on the diagram.
- Click/touch and drag on the diagram to find your part.
- Click/tap on the reference number in the diagram, or enter it here to filter the parts list table below.
Show Part
Need Help?
Call Shopsmith U.S. Based Customer Care — 937-890-5197Monday - Friday 8:30 am to 4:30 pm Eastern Time.
Email Customer Care — customerservice@shopsmith.com
Parts List:
Ref # | Part # | Description |
0z | Main Planer Assembly | |
1 | 513348 | Planer Front Top Cover |
2a | 502333 | Flat Washer |
2 | 513986 | Pan Head Screw |
3 | 514208 | |
4 | 518386 | Planer Cover with Warning Label |
5 | 513738 | Planer Rear Cover Pivot Screw |
6 | 513752 | Planer Outfeed Cover Logo Pivot Stud Retaining Ring |
7 | 449613 | Screw |
8 | 513751 | Planer Outfeed Cover Logo Pivot Stud |
9 | 51372304 | Shopsmith Logo Name Plate |
10 | na | Left End Frame |
11 | 516540 | |
14 | na | Right End Frame |
16 | 513720 | Planer Rear Cover Latch |
17 | 513721 | Planer Rear Cover Latch Spring |
18 | 513722 | Planer Rear Cover Latch Shaft |
19 | na | Spring Washer |
20 | na | Bearing Support |
21 | 120380 | Washer |
22 | 513386 | Socket Head Cap Screw |
23 | 513794 | .031" Thick Shim Washer |
24 | 513402 | Planer Feed Roller Gear |
25 | 120214 | Lock Washer |
26 | 513857 | Jointer Swing Guard Lock Nut |
27 | 513739 | Flat Washer |
28 | 513795 | Screw |
29 | 513746 | Planer Stock Thickness Scale |
30 | 513986 | Pan Head Screw |
31 | 513376 | Planer Feed Roller Tension Screw |
32m | Chain Tensioner Assembly | |
32 | 513389 | Planer Feed Roller Tension Spring |
33 | 513733 | Planer Special Washer |
34 | 120380 | Washer |
35 | 513381 | Planer Chain Tension Sprocket |
36 | 513375 | Planer Chain Idler Sprocket Pivot Screw |
37 | 513793 | Planer Chain Tensioning Bracket Mounting Screw |
38 | 513368 | Planer Chain Idler Sprocket Bracket |
39 | 120392 | Flat Washer |
40 | 115546 | Lock Washer |
41 | 120375 | Hex Nut |
41m | Feed Assembly | |
42 | na | Pro Planer Fee Motor |
43 | 513191 | Socket Head Screw |
44 | 120380 | Washer |
45 | 513391 | Planer Feed Assembly Woodruff Key |
46 | 513406 | Planer Feed Motor Mounting Screw |
47 | 502973 | |
48 | 513735 | Planer Feed Motor Retaining Ring |
49 | 513403 | |
50 | 51341503 | |
51 | 513411 | Planer Control Box Safety Key |
52 | 513760 | Planer Control Box Mounting Screw |
53 | 514736 | |
56m | Table Assembly | |
57 | na | Table |
58z | na | Crank Assembly |
58 | 51413703 | Planer Elevating Crank Assembly |
59 | 513397 | Planter Table Elevating Screw |
60 | 514036 | Planer Table Connector |
61 | 514037 | Planer Table Connector, Barrel Nut |
62 | 51399401 | Planer Table Locking Set Screw |
63 | na | Washer |
64 | 513730 | Planer Tie Bar and Bushings |
65 | na | Shim Washer |
66 | na | Tension Adjustment Sprocket |
67 | na | Roll Pin |
68 | 513857 | Jointer Swing Guard Lock Nut |
69 | 513387 | Planer Table Elevating Chain |
70 | 51398901 | Locking Set Screw |
71 | 513380 | Planer Stock Thickness Scale Pointer |
72z | Anti-kickback Assembly | |
72 | 513986 | Pan Head Screw |
73 | 513395 | Planer Anti-Kickback Rod |
74 | 513393 | Planer Anti-Kickback Assembly Long Tube Spacer |
75 | 513794 | .031" Thick Shim Washer |
76 | 513369 | Planer Anti-Kickback Wedge |
77 | 513394 | Planer Anti-Kickback Assembly Short Tube Spacer |
78z | Feed Roller Assemblies | |
78 | 513385 | Planer Sprocket-Locking Cotter Pin |
79 | 514534 | Planer Outfeed Roller Kit |
80 | 513391 | Planer Feed Assembly Woodruff Key |
81 | 555115 | Planer Serrated Steel Infeed Roller Upgrade |
82 | na | Special Washer |
83 | na | Pivot Screw |
84 | na | Pivot Arm |
85 | na | Washer |
86z | Cutterhead Assembly | |
86 | na | Spacer Washer |
87z | na | Cutterhead Assembly (incl 88-93) |
87 | na | Chip Deflector |
88 | na | Cutterhead |
89 | 502899 | Jointer Cutter-Head Knife Leveling Screw |
90 | na | Ball Bearing |
91 | 513406 | Planer Feed Motor Mounting Screw |
92 | 513363 | Planer Cutterhead Wedge |
93 | 505982 | Planer Knives (Set of 3) |
93m | Miscellaneous | |
94 | 513414 | Planer Knife Setting Gauge |
95 | 51368601 | |
96 | 51368604 | 3/16" Short Arm Hex Wrench |
97 | 51368607 | 1/8" Hex Short Wrench |
98 | 51368605 | 3/32" Hex Wrench |
