Belt Sander Service Parts
Find Your Part
  • Use the zoom tool, mouse wheel, or pinch to zoom on the diagram.
  • Click/touch and drag on the diagram to find your part.
  • Click/tap on the reference number in the diagram, or enter it here to filter the parts list table below.
Show Part
Need Help?
Call Shopsmith U.S. Based Customer Care — 937-890-5197
Monday - Friday 8:30 am to 4:30 pm Eastern Time.
Email Customer Care — customerservice@shopsmith.com
Parts List:
Ref # Part # Description
0m Main Assmbly
0z 502955 (incl 1,2)
1 N/A Tracking Screw
2 N/A Rollpin, 5/32 x 11/16
3 502958 Belt Sander Stop Nut
4 502957 Belt Sander Tracking Knob
5 515813 Plug Cap
6 502960 Belt Sander Tie Bolt
7 502959 Belt Sander Table Spacer Tube
8 120382 Washer
9 120377 Hex Nut
10 222460 Set Screw
11 503024 Belt Sander Tinnerman Clip
12 5030049 Belt Sander Auxillery Shaft Cap
12z 513061 (incl 13-15)
13 N/A Table Tilt Lock
14 N/A Retaining Ring
15 N/A Locknut
16 502999 Belt Sander Table Tilt Indicator
17 502998 Belt Sander Indicator Washer
18 N/A Self Tapping Screw #8-32x1/4
19b 124818 Hex Jam Nut
19 51485402 Belt Sander Dust Chute
19a 514521 Dust Collector Elbow Attachment
20 502698 Belt Sander Hex Stop Nut
21 502988 Belt Sander Nut Cup
22z 503402 (incl 23-25)
22 120388 Flat Washer
23 N/A Base Casting
24 N/A Drive Stud
25z 515565 Inner Frame Assembly (incl. 26-28)
25 N/A Trunnion Guide
26 N/A Rollpin, 1/4 x 5/8
27 N/A Trunnion
28 N/A Right Frame Side
30 5029639 Belt Sander Back-Up Plate
31 514050 Belt Sander Platen Mounting Flat Head Screw
32 51553801 Belt Sander Outer Frame
33 445446 Tinnerman Clip
34 502985 Belt Sander Trunnion Washer
35 502974 Belt Sander Trunnion Stud
36 502989 Belt Sander Trunnion Lock Nut
36m Idler Drum
36z 502934 (incl 37-47)
37 513732 Roll Pin
38 502945
39 N/A Tension Cam
40 N/A Bearing
41 N/A Idler Drum
42 N/A Spring Plug
43 504553 Flat Washer
43a 515619 Belt Sander Idler Drum Spring Washer
44 502937 Belt Sander Thrust Washer
45 N/A Idler Shaft
46 N/A Torsion Spring
47 N/A Rollpin
47z 502874 (incl 48-54)
47m Tension Knob
48 N/A Retaining Ring
49 N/A Lock Washer
50 N/A Latch Spring
51 N/A Tension Knob
52 N/A Drive Screw
53 N/A Washer 1/8
54 N/A Knob Latch
55 501027 Belt Sander Retaining Ring
56m Drive Drum
56 502923 Jointer & Belt Sander Medallion
56z 502789 (incl 57-62)
57 N/A Ball Bearing
58 N/A Bushing
59 N/A Drive Drum
60 N/A Rollpin
61 N/A Drive Shaft
62 502932 Drive Sleeve
63 502961 Belt Sander Finger Spring Washer
64 513191 Socket Head Screw
64m Table
64z 503406 (incl 65-71)
65 N/A Rollpin, 1/4 x 7/8
66 120388 Flat Washer
67a 502318 Special Washer
67 518307 Belt Sander Table Tilt Lock Bolt
68 N/A Table
69 502992 Belt Sander Table Support Spacer
70 N/A Tilt Slide
71 N/A Drive Stud
71z 503407 (incl 72,73)
72 N/A Mounting Rod
73 N/A Table Support
73z Miscellaneous
74 5137779 Bandsaw & Belt Sander 6" Long Eccentric Post
75 115321 Set Screw
76 120377 Hex Nut
77 120394 Flat Washer
78 122181 Hex Bolt
79 5035769
80 222458 Allen Set Screw
81 51368601
