LED Utility Light
Illuminate Your View of Virtually Any Woodworking Operation
![Shopsmith LED Utility Light Black](/wp-content/uploads/products/utility_light_strip_sander_l.jpg)
New Gray Color
![Shopsmith LED Utility Light Gray](/wp-content/uploads/products/555506_utility_light_gray.png)
These handy LED Utility Lights feature a bright conical reflector that will focus loads of light exactly where you need it for ensuring the optimum in precision for tasks of all types.
Their tough, Lexan shades are designed specifically to withstand the heat generated by incandescent bulbs of up to 100 watts as well as the impact of accidental drops onto the shop floor.
The LED Bulbs are brighter, last longer, & are less fragile to avoid unnecessary breakage.
Each lamp comes with a convenient 6-foot cord, a flexible gooseneck that twists and turns in any position for focusing on your task (and staying where you put it). A unique U-shaped mounting support bracket can be attached to the side of any machine you like with two self-taping screws (included).
Put one on your MARK 7 or Mark V Smart Motor for drilling, drum sanding, routing, shaping or lathe turning.
![Utility Light Bracket](/wp-content/uploads/products/UtilityLightBracket.jpg)
Bundle & Save!
Buy 2 Get an additional 1 HALF PRICE!
Buy extra support brackets so you can move your light from machine to machine.
![Optional 2X Shade-Mounted Magnifier](/wp-content/uploads/products/shade_mounted_magnifier2_l.jpg)
Get a close-up view of small projects or tolerance-critical processes with the 2X power magnifier. It attaches to the shade of the Shopsmith’s utility light. It’s perfect for zooming in to get a super-clear view of miniatures and similar small projects — or any tolerance-critical operations. The 2″ deep by 4″ wide premium-quality, high-clarity glass lens provides a larger field of view and resists scratching.
![Shopsmith Utility Light -- T-Track Version](/wp-content/uploads/products/t_track_lamp.png)
This special fence light kit includes a Shopsmith LED Utility Light (Either Black 555503 or Gray 555506) and a special bracket for mounting it quickly to the T-Track on the top of your MARK 7 or Mark V‘s rip fence or the T-Slots in your work table surface (MARK 7 and Mark V Models 520, 510, 505 only).
Can also be used with later model Shopsmith bandsaws, bandsaw fences, and the Shopsmith router table kit. Just slide the bracket into position and lock with a quick twist to hold and aim your LED Utility Light exactly where you need it.
