Find Your Part
- Use the zoom tool, mouse wheel, or pinch to zoom on the diagram.
- Click/touch and drag on the diagram to find your part.
- Click/tap on the reference number in the diagram, or enter it here to filter the parts list table below.
Show Part
Need Help?
Call Shopsmith U.S. Based Customer Care — 937-890-5197Monday - Friday 8:30 am to 4:30 pm Eastern Time.
Email Customer Care — customerservice@shopsmith.com
Parts List:
Ref # | Part # | Description |
0z | 514716 | (incl 1-8) |
1 | 513600 | Wing Nut |
2 | 120394 | Flat Washer |
3 | 514747 | Lathe Duplicator Bracket Mounting Cap Screw |
4 | 514748 | Set Screw |
5 | 514706 | Lathe Duplicator Template Clamp |
6 | 514705 | Lathe Duplicator Template Spacer |
7 | 120393 | Flat Washer |
8 | 514745 | Lathe Duplicator Template Mounting Cap Screw |
9 | 514708 | Lathe Duplicator Mounting Bracket |
11 | 517940 | Lathe Duplicator Socket Head Cap Screw |
13 | 517938 | Lathe Duplicator Template Rack Double T-Slot Extrusion |
15 | 517977 | Lathe Duplicator Support Bracket Assembly |
16 | 513356 | |
18a | 518070 | Lathe Duplicator Spacer |
18 | 518065 | Lathe Duplicator Mounting Bracket Mounting Screw |
19 | 513201 | Socket Head Screw |
20 | 502333 | Flat Washer |
21 | 514777 | (incl 22) |
22 | 514776 | |
23 | 186923 | Socket Head Cap Screw |
24 | 120392 | Flat Washer |
25 | 515542 | |
26 | 514491 | Tee Nut (3 Holes) |
27 | 513600 | Wing Nut |
29 | 514708 | Lathe Duplicator Mounting Bracket |
30 | 120396 | Flat Washer |
31 | 514749 | Lathe Duplicator Carriage Bolt |
33 | 514744 | Steady Rest Clamping Cap Screw |
34 | 514697 | Lathe Duplicator Table Support |
35 | 514416 | Lathe Tool Rest Post |
37 | 514713 | |
38 | 513808 | |
39 | 514698 | Lathe Duplicator Tool Rest Foot |
42 | 139367 | Cone Point Set Screw |
44 | 51474001 | Lathe Duplicator Knob with Insert |
45 | 514746 | Lathe Duplicator Template Mounting Set Screw |
46 | 514707 | Lathe Duplicator Follower Support |
48 | 514750 | Lathe Duplicator Cutter & Guise Flat Washer |
49 | 514699 | |
50 | 514709 | Lathe Duplicator Follower Upright |
51 | 51474002 | Lathe Duplicator Star Knob w/Threaded Insert |
52 | 514238 | |
53 | 514742 | Lathe Duplicator Cutter Mounting Screw |
55 | 514719 | Lathe Duplicator Cutter Guide |
57 | 555211 | |
58 | 514710 | Lathe Duplicator Cutter Support |
59 | 514704 | Live Center Extension (for Lathe / Lathe Dup) |
60d | 51368609 | 7/64" Hex Wrench Long |
60c | 51368608 | 5/16" Hex Wrench Short |
60b | 51368604 | 3/16" Short Arm Hex Wrench |
60a | 51368606 | 1/4" Hex Wrench |
61 | 514714 | Lathe Duplicator Table |
80 | Optional Accessories | |
81 | 555210 | |
82 | 555212 | |
83 | 555213 | |
84 | 555278 | |
85 | 505602 | Tailstock Live Center |
