Shopsmith Mark 7
With powerpro generation 2 touchscreen
GET IN THE ACTION WITH THE
#1 MULTI-PURPOSE TOOL IN AMERICA
HERE’S WHY
Our Space-saving Tools Help You Get Professional Results.
The MARK 7 is a truly powerful machine that gives you 7 Great Tools in 1 Machine.
The MARK 7 has everything you need to make beautiful wooden projects, save money on DIY “fix-it” projects, or unleash your creativity with beautiful heirlooms.
It includes 7 of the most important tools you will need in your shop and only requires an amazing two-foot by six-foot storage space.
Just tuck it snugly away in a corner of your shop, garage or basement until you are ready to pull it out and go to work.
$5,249.00
![phone](/images/icons/phone.png)
ORDER BY PHONE
Call 937-890-5197
8:30am–4:30pm EST, MOn-FRI.
![](/images/banners/minute-overview-video-thumb.jpg)
The Minute Overview
Watch this video for a quick 60-second overview of the Mark 7.
![](/images/banners/full-demonstration-video-thumb.jpg)
The Full Demonstration
Watch this video for an in-depth look at the features of the Mark 7.
7 Tools. 1 Machine. A Lifetime of Results
SHOPSMITH 10″ TABLE SAW
Power, Accuracy and Versatility Provide Professional Results.
Every woodworking project begins by ripping and crosscutting your components to size. A top-quality table saw is vital to achieving the results you want. The Shopsmith 10″ Table Saw has the power, speed, and accuracy your project needs to achieve precise, smooth, burn-free cuts every time. Easy to install Extension Tables provide unparalleled workspace surface and when not needed, store away so that they are not taking up valuable shop floor space.
Plus, the Shopsmith’s 10″ diameter blade and powerful motor give you an ample depth-of-cut and up to 2 HP of raw muscle to zip through stock up to 3-1/4″ thick.
- 250 RPM to 10,000 RPM Variable Speed Drive
- 98″ Ripping Capacity With Extensions
- 95″ Of Back-to-Front Support With Extensions
- Miter Guage Safety Grip Allows 5X Gripping Power
- Self-Aligning, Double-Locking Rip Fence
![](/images/products/mark-7/mark7_saw1.jpg)
Shopsmith’s Quill Micro-Feed feature can be used to micro-adjust the saw blade when you need super-precise cuts like shaving dado slots or grooves for a snug fit, and when you need to create tight fitting tenons or adjust miter cuts.
Shopsmith 12” Disc Sander
Effortless Operation That Smoothes Out The Rough Edges.
The Shopsmith Disc Sander is truly in a class by itself. No other disc sander (including big money commercial units) offers the extensive assortment of work-saving features and benefits. Shopsmith’s quill feed feature, you can actually move the Disc up to 4-1/4″ toward or away from your stationary workpiece. This unique feature allows you to make quick, easy micro-adjustments when sanding single or multiple components to a precise, identical dimension.
- Large 17-1/2” x 22” Worktable Before Extensions
- Infinitely variable Speed Range
- Flexible Dust Collection Capabilities
- Included Miter Gauge and Rip Fence For Quick Fixturing
![](/images/products/mark-7/mark7_disc_sand1.jpg)
The Shopsmith 12″ Disc Sander provides best in class performance and options. With a giant 17″x22″ worktable plus extensions, reversible motor, quill micro-feed and variable speed at the push of a button, the 12″ Disc Sander give you all the capabilities to improve the precision of your work and save you time.
Shopsmith 34” Lathe
Bring Out Your Inner Artist Using The Shopsmith Lathe.
Lathe woodturning is relaxing, enjoyable and gives you immediate results. Imagine the feeling of creating a beautifully crafted platter, bowl, vase or similar object on the lathe that you shaped and smoothed yourself. Just apply finish and they’re ready to admire!
And, if you’re like many other woodworkers, you’ll also use the lathe for those money-saving D-I-Y projects or ultimate new creations such as:
- Chair and Table Legs
- Spindles for Beds and Porches
- Stair Railings
- Posts for Fences or Mailboxes
- Holiday and Birthday Gifts
- And, Many Other Applications
![](/images/products/mark-7/mark-7-lathe1.jpg)
The Full-Featured Shopsmith Lathe offers generous diameter and between-center capacities, so it can handle faceplate turnings big enough to make large salad bowls or spindles long enough for table legs or stair spindles.
Shopsmith horizontal boring
Convenient Precision and Repeatability That Saves Time.
Horizontal Boring Machines are major time-savers for a lot of different jobs. If you don’t believe that or have never heard of a horizontal boring machine, just ask an experienced cabinetmaker. The most obvious application for this machine set-up is doweling. Tilt your worktable to 20° and you have a built-in fixture for screw pockets.
And of course, as with all operations the variable speed feature (250 to 10,000 rpm) of the PowerPro Smart Motor lets you match your machine’s speed to the wood species and drill bit diameter for smoother holes without burning. Even the expensive commercial boring machines don’t offer this kind of variable speed flexibility!
- Electronic Variable Speed
- Center Drilling in the Horizontal Position
- Horizontal Mortising Capabilities
- Adjustable Quill Feed Depth-Of-Cut Dial and Lock
![](/images/products/mark-7/mark7_horizontal_bore1.jpg)
Thanks to its unique table system, the accuracy of the Shopsmith Horizontal Boring Machine stands toe-to-toe with commercial models.
Shopsmith 16-1/2” Drill press
Loads of Muscle. Plenty of Speed.
The Shopsmith Drill Press combines extended work holding capacity, easy speed changes and superior versatility to provide an exceptional drill press, designed specifically for woodworkers. With a motor that delivers up to two horsepower and an amazing amount of torque at an infinitely variable speed range of 250 to 10,000 rpm – and you can change speeds at the touch of a button.
Drill to the center of a piece of stock up to 16-1/2″ in diameter. Enjoy 25″ of chuck-to-worktable surface distance and 58″ of chuck-to-floor distance. Get a full 4-1/4″ of up-down spindle travel controlled by a convenient, graduated hole depth indicator and easy-to-set adjustable stop. This Drill Press has plenty of capacity, even for your biggest jobs!
- Drill Wood, Plastics, and Metals
- Twin, Non-Twisting Support Columns
- Tilts from 0° to 90°
- Change Speeds in 1 RPM Increments
- Included Miter Gauge and Rip Fence Make for Quick Fixturing
![](/images/products/mark-7/mark7_drill2.jpg)
Get the most out of the Shopsmith Drill Press. While other machines sacrifice workspace, speed or spindle travel – the Shopsmith Drill Press offers a wide range of capabilities without sacrificing the performance you need and expect.
Shopsmith Over-Table Stationary Router
Power And Speed to Create Smooth Decorative Edges and Precise Joinery.
The Shopsmith MARK 7 gives you a full-featured, Over-Table Stationary Router. As an Over-Table Router, the machine is set up with the bit positioned above your workpiece. In this setup, depending on the operation being performed (dadoing, grooving and slot mortising are excellent examples), the operator always has a clear view of the cut as it’s being made.
Woodworkers who are not normally comfortable using hand-held routers will find that the MARK 7’s stationary router has been designed to give you the confidence to get great results.
- Easily Converts from Drill Press to Over Table Router
- Full Tilting 17″ x 22″ Worktable plus Extensions
- 10,000 RPM Creates Smooth Cuts
- Full Torque Across the Entire Speed Range
- Included Miter Gauge and Rip Fence for Quick Fixturing
![](/images/products/mark-7/mark7_router1.jpg)
The Over-Table Router is capable of 1-3/4 to 2 horsepower of continuous torque to tackle your toughest jobs. Infinitely adjustable speeds from 250 to 10,000 RPM provides pro-results. Utilize the full length of plunging-type straight router bits to perform routing operations deep within project components.
Shopsmith Under-table Shaper
The new MARK 7 will function like a commercial shaper with the cutter below the worktable, a method preferred by many woodworkers. Some commercial shapers only offer two or three speeds. Shopsmith gives you the ability to select an infinite range of speeds in 1 RPM increments!
Tilt your worktable to make unique and specialized cuts — a capability that even commercial shapers costing thousands don’t offer! Thanks to the MARK 7‘s full tilting worktable, you can make an infinite range of unique, angled, decorative-edging cut combinations that are impossible to achiece with fixed-table commercial shapers.
- Easily Converts to Under-Table Shaper
![](/images/products/mark-7/mark7_shaper1.jpg)
With the MARK 7, you can change the direction of the motor to cut in either forward or reverse direction. As a result, if you prefer, you can invert the cutter on its arbor and reverse the feed direction of your stock from one side of the worktable to the other.
Let Us Build You a Shopsmith Today
Shopsmith is ready to build you a new MARK 7! You will enjoy a 90-Day Money-Back Guarantee – Try your new Shopsmith in your own home shop for a full 90 days. Use it to build any project – as many as you like. Then, if you don’t agree that it’s all we’ve said, simplify notify us and we’ll tell you how to return it.
Shopsmith MARK 7 with PowerPro & Pro-Fence Table System 557000
$5,249.00Add to cart
ORDER BY PHONE
Call 937-890-5197
(Please allow 2 to 4 weeks for delivery – For AK/HI Shipping, call Customer Care)
HERE’S WHY MARK 7 IS BETTER
Enjoy All the Woodworking Capabilities You Could Want
— in the Space You Have Now!
The Individual Tool Workshop
The left side of this diagram shows how the collective storage footprint required to house just 7 of the common tools in a Workshop will promptly boot one of your family cars right out of the garage! Plus, you’ll have loads of time-consuming tool shuffling to do before you can start enjoying your shop time.
The Compact Shopsmith Workshop
The right side of this diagram shows how the Shopsmith Multi-purpose Tool shop (including every tool you see in the left side of the diagram, plus more) stows neatly away on the floor and on a shop-made, wall-mounted shelf…occupying just 2 feet x 6 feet of floor space along the front of the garage. Plenty of room to work without excess tool shuffling — and ample space for two family cars.
Individual tools workshop
Shopsmith workshop
![Space saving diagram](/images/products/mark-7/space-saving-diagram.jpg)
No other power tool on the Market can Match Shopsmith’s Space-saving Convenience and Awesome Versatility. None.
Changing from Tool-to-Tool is Quick, Simple, and Takes Only Seconds
Only 1 Machine to Learn, Not 7
Quick-acting locks, wheels, wingnuts, and handles provide for rapid tool positioning and lock down – and all spindle-mounted accessories can be attached and removed with just one tool— the 5/32″ allen wrench that comes with your Machine.
In fact, after only a short amount of time working with your Shopsmith, you’ll begin to notice that your projects will flow more smoothly from one operation to the next as your experience guides you to work with increasing efficiency!
SHOPSMITH MARK 7
1 Machine, 7 Tools, Quick & Easy Changeovers. WATCH THE DEMONSTRATION VIDEO
“I’ve heard the objections (about changeovers) many times from people who don’t own a Shopsmith— but I have never heard it from Shopsmith Owners!”
Fred Wescott
North Scituate, MA
Switch from Tool to Tool in Under 2 Minutes
Ask any Shopsmith Owner about changeovers and you’ll quickly be told that the issue practivally never enters their mind. Changeovers become second nature and are normal steps you take to complete your project
Seconds
Drill Press to Lathe
Seconds
Lathe to Table Saw
Seconds
Table Saw to Disc Sander
Seconds
Over Table Routing to Under table Shaping
Seconds
Horizontal Boring Machine to Drill Press
Seconds
drill Press to Over Table Routing
Seconds
Disc Sander to Horizontal Boring Machine
EXPERIENCE THE PURPOSELY-ENGINEERED MARK 7
ONE SET OF CONTROLS FOR ALL 7 TOOLS
![Mark 7 Features](/wp-content/uploads/M7PP2-Features.png)
These carefully-engineered features will make the MARK 7 easier to use and help you achieve better results!
CONTROL PANEL
Push button control for selecting variable Motor speeds (250 – 10,000 RPM in 10 RPM increments) and direction
MAIN POWER SWITCH
Child-proof with detachable key to prevent accidental starts
POWERPRO Smart Motor
State-of-the-art DVR (Digital Variable Reluctance) Motor develops 1-3/4 hp at 120 Volts or 2 hp at 240 Volts and is totally enclosed and fan cooled for durability. Click here for a quick overview of the features and benefits provided by Shopsmith’s PowerPro Smart Motor and DVR Motor
Smart Motor LOCK
Locks Smart Motor at any location along the tubular ways
QUILL HANDLE
Used to extend the Quill to its 4-1/4″ capacity
CARRIAGE
Supports Table and Lathe Tool Rest. Slides full length of tubular
ways
TABLE HEIGHT LOCK
Locks Table height settings
TABLE HEIGHT WHEEL
Uses geared rack-and-pinion system to raise and lower table
CARRIAGE LOCK
Locks Carriage at any position along tubular ways
BENCH ENDS & TUBES
Provide rigid, wobble-free base for machine
BASE ARM LOCK
One on each end of machine to secure machine safelv in vertical
position in both directions for over-table Drill Press-based operations – or under-table Shaping operations
EXTENSION TABLE
Mounts at either end of machine for added workpiece support
RIP FENCE
Locks at front and rear of table for precise ripping or use as a
positioning aid when drilling, sanding or performing other operations
AUXILIARY SPINDLES
Used to power Bandsaw, Jointer & other Major Accessories
MITER GAUGE
Includes special work-holding Safety Grip and adjustable auto-stops
at common angles
POWER MOUNT
Used to mount Extension Table or Major Accessories
HORIZONTAL LOCKS
One on each end of machine.used to tilt Smart Motor & table from
horizontal to vertical position for drilling and over or under-table Drum Sanding, Routing or
Shaping operations
SAW GAURDS
Upper and lower guards provide operator safety and built-in dust
collection port
TELESCOPING LEGS
Provide added support for floating extension table
A Full Complement Of Standard Accessories
To Help You Get Started On The Road To Woodworking Success!
![Mark 7 Standard Accessories](/images/products/mark-7/standard-accessories.jpg)
Upper & Lower saw Guards
Includes built-in dust collection port & see-through upper guard with riving knife. Dual, cam-style pawls prevent
kick-backs
10″ All-Purpose Saw Blade
Premium quality, 50-tooth carbide-tipped blade for ripping & crosscutting
Saw Blade Arbor
Large, 1-1/4″ diameter arbor is specially designed to provide added blade support & smooth-running operation
Aluminum Rip Fence
Locks at both front & rear of table for precision ripping – also serves as a guide and/or backstop for drilling, sanding
& other operations – offers two T-slots on top surface & one on each face of fence for attaching jigs & fixtures
Miter Gauge
Squeeze-style safety grip clamps the workpiece firmly to the gauge bar for slip-free operation – protractor is accurate
to 1/2°, with adjustable auto-stops at common angles – gauge bar slides in T-shaped table slots to prevent accidental drops & provide extended crosscutting capacity
Extension Table System
Includes one base-mounted & two floating style tables with four connecting tubes & two telescoping legs for added
workpiece support ways
Shopsmith Safety Kit
Award-winning kit includes a push stick, a push block with anti-slip foam bottom, a fence straddling push block & an
adjustable feather board
Safety Goggles
Wrap-around style with ventilated sides – work over glasses without fogging
12″ Sanding Disc & Sandpaper
Steel disc with 113 sq. in. of surface – Includes one pressure-sensitive, medium grit sandpaper disc
Lathe Centers
Spurred drive center & cup-style dead center for spindle turning
Lathe Tool Rest
Slides into table carriage to provide support for lathe chisels during turning
Lathe Tailstock
Adjustable mount holds dead center (or optional live center) during turning – Adjusts for offset turning such as
Cabriole Legs
Drill Chuck & Key
1/2″ capacity geared
Allen Wrenches
The only tools you’ll need to change operations
Coupling Kit
Used to power Bandsaw, Jointer & other major accessories – includes one unbreakable Zytel Coupler & two drive hubs
at common angles
Shaper Arbor
1/2″ arbor includes four assorted size rub collars
Shaper / Router Shield
Used for routing and under-table shaping- attaches to back of worktable & provides dust collection hook-up
Shaper/ Router Table Insert
Features 2-1/4″ diameter center hole – includes two threaded starter pins for shaping & mounting holes on underside for
shaper vacuum attachment (Vac attachment cannot be used during under-table shaping or routing
1/2″ Router Chuck
Precision-machined steel chuck accepts all Router Bits with 1/2″ shanks
Arbor Wrench
Ends fit both positions on Arbor plus the nuts on the Dado Arbor and Shaper Arbor
Shopsmith Owner Testimonials
I have been a Shopsmith owner for over 30 years…Simply put, I wouldn’t give it up for anything. Every time I seem to need a tool for something, I look at my Shopsmith and say ‘It can do that’… It’s the best, most comprehensive tool I’ve ever invested in.
– T. Peter, Florida (via email)
The Can’t Miss Details
Shopsmith gives you 7 of the most valuable woodworking tools for your shop, in 1 powerful platform. Click any of the buttons below to see the key details that make Shopsmith the best tool to create breathtaking results.
ORDER BY PHONE
Call 937-890-5197
Owner Projects and Project Ideas
Check Out this Gallery to See Awesome Projects Built with Shopsmith
