Shopsmith’s Miter Gauge and Accessories Deliver Precision, Safety and Repeatability
Making precision saw cuts — guiding workpieces precisely through Molding, Dadoing, Shaping & Routing operations — and controlling your stock during Sanding are all jobs that require the help of a reliable, accurate Miter Gauge… and Shopsmith’s Miter Gauge and its related accessories are ready to fill those needs for you.
![Forms The Basis For a Complete System Of Work-Holding and Guiding Devices](/wp-content/uploads/products/miter_gauge_with_safety_grip_l-1024x664.jpg)
Miter Gauge Package
The Miter Gauge Package includes the Miter Gauge and the Safety Grip.
Shopsmith Miter Gauge
The Shopsmith Miter Gauge forms the basis for this complete system of work-holding and guiding devices. It offers a built-in scale that reads from 0° to 30° left and right an adjustable “zeroing” pointer that lets you measure down to 1° increments adjustable auto-stops at 0° and 45° in both directions and a large, knurled knob to lock the gauge into position. A 1/4″ hole runs through the face (left-to-right) for inserting the optional stop rod.
![Measure Down to 1 Degree Increments](/wp-content/uploads/miter_gauge_l-1024x462.jpg)
Miter Gauge Safety Grip
The Miter Gauge Safety Grip attaches to the miter gauge with a single screw and the top screw-in post. One pound of pressure on the grip exerts five pounds of holding pressure between the safety grip pad and the top of the miter bar to keep the stock from slipping during the cut. Quick-release knob adjusts rapidly for stock up to 4-1/4″ thick.
![Exerts 5 Times the Holding Pressure](/wp-content/uploads/safety_grip_l-1024x819.jpg)
Quick-Clamp Miter Gauge Retro-Fit Kit
The Model 500 MARK V Quick-Clamp Miter Gauge Retro-Fit Kit replaces the thumb-screw adjustment mechanisms on older Shopsmith miter gauges. A real time-saver!
![ime-Saving Quick-Clamp Retro-Fit](/wp-content/uploads/miter_gauge_quick_clamp_retro_l.jpg)
Miter Gauge Stop Rod
The Miter Gauge Stop Rod adjusts to make repetitive crosscuts up to 19-1/4″ from the saw blade. Includes two setscrews for attaching to the miter gauge.
![Miter Gauge Stop Rod](/wp-content/uploads/mitergauge_stoprod_l.jpg)
![Hardwood Extension For Added Workpiece Support](/wp-content/uploads/mitergauge_hdwd_ext_l.jpg)
24″ Aluminum Miter Gauge Extension
The 24″Aluminum Miter Gauge Extension mounts quickly and easily to the face of your Shopsmith miter gauge with two mounting bolts and knurled locking knobs. Stop block (included) adjusts to make repetitive crosscuts up to 24″ long.
![24-Inch Aluminum Miter Extension](/wp-content/uploads/555429l.jpg)
20″ Aluminum Miter Gauge Extension
The 20″ Aluminum Miter Gauge Extension attaches to your miter gauge face via rear T-Slots with two bolts and knurled knobs. The adjustable stop slides to the left or right in a top-mounted T-Slot and can be flipped up or down when needed. The extension (with stop) slides left or right on the gauge face to allow repetitive cut-offs up to 20″ long.
![20" Aluminum Miter Gauge Extension](/wp-content/uploads/products/miter_gauge_alum_20_ext.jpg)
Miter Bars
Miter Bars are made to fit all model MARK 7 and MARK V work tables, Shopsmith aluminum bandsaw tables and T-Slotted router tables. MARK 7 and MARK V Model 505, 510, 520 version includes removable T-Slot washer. MARK V model 500 version does NOT include T-Slot washer.
![Miter Bars](/wp-content/uploads/MitreBars.jpg)
The Miter Bar for Jigs & Fixtures includes steel miter bar with T-Slot washer to prevent accidental lift-out and mounting holes with counterbores for three 1/4-20 by 1/2″ long buttonhead screws (included). Also includes three mating 1/4-20 threaded inserts for attaching miter bar to jig or fixture and a hex key for installing threaded inserts.
![Miter Bars](/wp-content/uploads/jigsfixturesB.jpg)
