POWER-UP YOUR MAJOR ACCESSORIES &
FREE UP YOUR MARK!
Shopsmith’s All-Inclusive, Machine-Specific Power Stands Give You Ready-To-Go Woodworking Convenience for Your Shopsmith Special-Purpose Tools!
STURDY. LIKE NO OTHER.
The NEW! Shopsmith SPT Power Stand is dressed-to-impress with custom-made, heavy-duty steel construction. The heavy-gauge-steel, tapered legs are larger at the top to support the weight of all your Shopsmith Special Purpose Tools securely, and run with less vibration
![uploads - new_spt_composite](/wp-content/uploads/new_spt_composite.jpg)
Get The NEW! Shopsmith Power Stand for each of Your Shopsmith Special Purpose Tools including Bandsaw (#1 Selling Accessory), Belt Sander, Jointer, Scroll Saw, & Strip Sander.
No need to switchover each time you want to use one of your Special Purpose Tools just power up whenever you are ready by using Your Power Stand. The Shopsmith Power Stand makes sure Your Special Purpose Tools are ready when you are!
- With Your Shopsmith Power Stand, there is no more lifting back and forth.
- Small footprint – just store in a corner and slide it out as needed.
- Made exclusively for the Shopsmith Woodworking System with sturdy all steel construction Powder Coated for durability.
- Plus, a NEW! Heavy-Duty, 1.25 Service Factor, 3/4 HP 11.3-amp motor ready to deliver an additional 25% performance output, on-demand, to handle even the toughest jobs with ease – THAT’S NEARLY 1-FULL HP OF TOP-END PERFORMANCE!
Special Purpose Tools Shown for Display Purposes Only. Special Purpose Tools Sold Separately.
Order on the Web or by Phone, if you prefer — (937) 890-5197.
Call before 4:30 PM Eastern Time
