Find Your Part
- Use the zoom tool, mouse wheel, or pinch to zoom on the diagram.
- Click/touch and drag on the diagram to find your part.
- Click/tap on the reference number in the diagram, or enter it here to filter the parts list table below.
Show Part
Need Help?
Call Shopsmith U.S. Based Customer Care — 937-890-5197Monday - Friday 8:30 am to 4:30 pm Eastern Time.
Email Customer Care — customerservice@shopsmith.com
Parts List:
Ref # | Part # | Description |
1 | 518271 | |
1b | 518249 | |
1a | 518248 | |
2 | 518163 | Scroll Saw Fixed Arm Hood |
3 | 515165 | Scroll Saw Hood Bracket |
4 | 515120 | Self-Tapping Hex Washer Head Screw |
5 | 506721 | Dowel Pin (1/4 X 7/8 Inch) |
6 | 515166 | Scroll Saw Hood Spring |
7 | 186923 | Socket Head Cap Screw |
8 | 120380 | Washer |
9 | 514965 | Scroll Saw Fixed Arm Tubing Cover |
10 | 518177 | Scroll Saw C-Frame Outer Washer |
11 | 518159 | Scroll Saw Barrel Nut |
12 | 518047 | |
13 | 518155 | |
14 | 518127 | Scroll Saw Tension Lever |
15 | 518178 | |
16 | 455862 | Roll Pin |
16a | 455734 | Roll Pin |
17 | 518154 | Scroll Saw Upper Blade Block |
18m | 518156 | |
18 | 518345 | |
20 | 518223 | Scroll Saw Lower Blade Block |
21 | 518160 | Scroll Saw Tension Knob Spacer |
22 | 514974 | Scroll Saw C-Frame Blade Tensioning Upper Rocker |
23 | 514980 | Scroll Saw Blade Tensioning Return Extension Spring |
24 | 514040 | Pan Head Screw |
25 | 518266 | Scroll Saw Upper Arn with Shaft |
26 | 518179 | Upper Arm Blade Block Mounting Roll Pin |
27 | 514975 | Scroll Saw C-Frame Blade Tensioning, Lower Rocker |
28 | 514236 | Button Head Screw |
36 | 518265 | Scroll Saw Lower Arm with Shaft |
38 | 513732 | Roll Pin |
39 | 518111 | Scroll Saw Tensioning Rod |
41 | 514411 | External Retaining Ring |
42 | 514979 | Scroll Saw Blade Mounting Lock Pin Spring |
43 | 514978 | Scroll Saw Blade Mounting Lock Pin |
44 | 514353 | Rip Fence & Table Tilt Lock Compression Spring |
45 | 514407 | External Retaining Ring |
46 | 515072 | Scroll Saw Puffer Pump Rod |
47 | 515178 | |
48 | 515119 | Scroll Saw Pump Seal Washer |
49 | N/A | Jigsaw Pump Seal |
50 | 514053 | Flat Washer |
51 | 515299 | Scroll Saw Locking Hex Nut with Nylon Insert |
52 | 515073 | Scroll Saw Puffer Housing |
53 | 515105 | |
54 | 514967 | Scroll Saw Lower Arm Link Assembly |
55 | 514973 | Scroll Saw Lower Arm Link Bolt |
56 | 518165 | |
57 | 518243 | Scroll Saw Cable Clamp |
58 | 518125 | Scroll Saw Hold down Spring |
59 | 513897 | Hex Nut |
60 | 517978 | Scroll Saw Button Head Cap Screw |
61 | 517982 | Button Head Cap Screw |
62 | 518094 | Scroll Saw Hold Down Post |
63 | 120391 | Washer |
65 | 518338 | |
66 | 518153 | Scroll Saw Table Pivot Screw |
67 | 518152 | Scroll Saw Table Pivot Spacer |
71 | 518274 | Scroll Saw Front Trunnion |
72 | 515127 | Scroll Saw Table Tilt Trunnion Mounting Screw |
73 | 518431 | |
74 | 518009 | Flat Washer |
75 | 518273 | Scroll Saw Trunnion Base |
76 | 502885 | Depth and Angle Pointer |
77 | 513623 | Pan Head Screw |
78 | N/A | Frame Assembly, RH |
79 | N/A | Frame Assembly, LH |
80 | 518175 | Scroll Saw C-Frame Right Hand Arm Spacer Washer |
80a | 518176 | Scroll Saw C-Frame Left Hand Arm Spacer Washer |
81 | 516232 | |
82 | 518141 | Screw 1/4-20x2-1/2 |
85 | 513885 | Hex Nut |
87 | 518102 | Scroll Saw Rear Cradle |
90 | 518188 | Scroll Saw Base |
91 | 514992 | Scroll Saw Base Plate |
93 | 513201 | Socket Head Screw |
95 | 120392 | Flat Washer |
96 | 515071 | Scroll Saw Drive Shaft with Pinion Gear |
97 | 518360 | |
98b | 515089 | Scroll Saw Counterweight Hard Gear |
98a | 518172 | Scroll Saw Weight and Shaft Soft Gear |
99 | 517982 | Button Head Cap Screw |
100 | 502973 | |
101 | 515118 | Scroll Saw Gear Cover |
