Find Your Part
- Use the zoom tool, mouse wheel, or pinch to zoom on the diagram.
- Click/touch and drag on the diagram to find your part.
- Click/tap on the reference number in the diagram, or enter it here to filter the parts list table below.
Show Part
Need Help?
Call Shopsmith U.S. Based Customer Care — 937-890-5197Monday - Friday 8:30 am to 4:30 pm Eastern Time.
Email Customer Care — customerservice@shopsmith.com
Parts List:
Ref # | Part # | Description |
285 | 505715 | Lathe Drive Center Complete |
286 | 222458 | Allen Set Screw |
287 | 505716 | Lathe Cup Center |
287a | 504276 | (incl 288-292) |
288 | 5014379 | Lathe Tailstock Center Eccentric Mount |
289 | 102581 | Allen Set Screw |
290 | 501438 | Stop Collar Assembly |
291 | 501439 | Collar Assembly (Single) |
292 | 222458 | Allen Set Screw |
292a | 514398 | (incl 293-297) |
293 | 514416 | Lathe Tool Rest Post |
294 | 514264 | Lathe Tool Rest Arm & Lever Upgrade (for MARK 7/MARK V 520, 510, 505) |
295 | 503749 | Standard Lathe Tool Rest, 8" Long |
296a | 521688 | MARK 7 / MARK V 520/510/505/500 Lathe Tool Rest Short Lever |
296 | 521689 | MARK 7 / MARK V 520/510/505/500 Lathe Tool Rest Long Lever |
297 | 102585 | Screw |
297a | 505633 | (incl 298-300) |
298 | 501420 | (incl 299) |
299 | 222460 | Set Screw |
300z | 514468 | (incl 301-302) |
300 | 501419 | 1/2 Inch Drill Chuck Key (Key Only) |
301 | 503570 | (incl 304) |
302 | 503574 | |
303 | 503738 | (incl 304) |
304 | 222458 | Allen Set Screw |
305 | 513456 | Safety Goggles |
306 | 518221 | Edgewood Push Stick |
307z | 518215 | (incl 308-312) |
307 | 518220 | Edgewood Push Block Assembly |
308 | 518216 | |
309 | 513705 | Featherboard Flathead Screw with Rubber Ring Asmembly |
310 | 513707 | Featherboard Expansion Bar |
311 | 513713 | Knob with Insert |
312 | 513864 | Flat Washer |
312z | 521107 | (incl 313-317) |
313 | 521106 | Fence Straddler |
314 | 513706 | Straddleblock Slide Rail |
315 | 513713 | Knob with Insert |
316 | 521418 | MARK 7 / MARK V520 Fence Straddler Side Mounting Screw |
317 | 513864 | Flat Washer |
318 | 555958 | Carbide-tipped Combination Saw Blade |
318z | 555130 | (incl 319-321) |
319 | 222458 | Allen Set Screw |
320 | 514400 | |
321 | 514401 | |
322 | 505841 | |
322z | 555143 | (incl 323-326) |
323 | 513144 | |
324 | 514493 | Disc Sander Hub |
325 | 222460 | Set Screw |
326 | 513153 | Flat Head Screw |
327 | 513923 | |
328 | 515979 | Universal Wrench |
329b | 505717 | (not shown) |
329c | 555069 | (not shown) |
329a | 845620 | (not shown) |
